Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 08-10-2005, 07:45 PM
veritas veritas is offline
Unhappy 1986 Town Car, just bought it....problems...
Just bought an 86 TC, looks amazing, very well kept...i've had it a few days and....Drivers side Power Window has stopped working...unfortunatly its down, and I cant get it up, and the forecast is calling for rain...problem number 2 is...when driving slow it feels like its about to choke, and when starting off, when you first press the gas it hesitates...any ideas?
I called the local LIncoln dealer about the window, he says they can fix it, ANy Ideas how much that will cost? Also bought some Slick 50 gas system cleaner, hoping that will clear up the hesitation and choking problems....
Old 08-11-2005, 04:21 PM
Towncar's Avatar
Towncar Towncar is offline
For the downed window:
If you can hear the motor spinning, yet the glass wont move it's most likely the clutch bushings are shot. Their an internal part of the lift motor assembly providing a clutch action if you happen to snag an arm or leg while closing the glass.
You can get these clutch bushings all over the place and do the repair yourself but it's allot of work. On the other hand the dealers and shops wont mess with these bushings, they'll just replace the entire regulator, track, and motor assembly, costing you hundreds.
The bushings are about $5.00 and worth about $.50 cents.
-Steven
1996 Town Car, Cartier
Old 04-21-2008, 09:09 PM
ketchamized ketchamized is offline
Re: 1986 Town Car, just bought it....problems...
This is kind off the point, but I had a '86 Lincoln Town Car a few years ago.
It was a great car, and a joy to drive. But, the strangest thing about it was, whenever it rained or snowed outside, the car would not start or even turn over at all. Even if it rained or snowed "lightly". I never figured out what the cause was. I don't know if that's common with that year, just thought I'd mention it in case.
For the heistation and choking problems, I'm very partial to the "Lucas Fuel Injector Cleaner". This stuff works really well. For extreme cases, you can use "Sea Foam".
Cheers,
Erick
Current owner of '94 Lincoln Town Cartier
Old 04-21-2008, 09:24 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Lucas makes great products! I use all of them
Old 04-21-2008, 09:48 PM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
Replace that fuel filter.
Mike aka JYD
Old 04-22-2008, 12:50 AM
danielsatur danielsatur is offline
This car has been around for a while! 1st Generation TC
1) This car does come equipt with EGR,CATS,and PCV for emmissions.
2) The car must of been sitting around, than putting all that gunk
back into the Intake!
3) What about your Catalaytic converters! ,are they blocked?
What would MCGIVER DO ?
(A) Compression check on all cylinders.
(B) Block EGR port with home made gasket.
(C) Remove catalaytic converters.
(D) New Air filter.
(E) '' Pcv valve.
(F) '' fuel filter. (JYD)
(G) '' Spark plug wires + plugs.
(H) Out of car injector service.
Hey! this sounds like an extream case ''Lets try SEAFOAM'' (ERIC)
4) How many miles does this car have on it?
5) What kind of cond?
6) How much is she worth?
7) What kind of budget are we working with?
HEY GUYS - We don't need windows for a demolition derby!,this car would do better than sck38's!
HEY! This Thread is years old,this car is probably already crushed.
