Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 08-10-2005, 06:26 PM
mgjetta mgjetta is offline
Unhappy Over heating
I have a 99.5 Jetta. A couple days ago the car started to overheat, the fans wouldn't cycle, but if I put the ar in neutral and shot the car off for a couple seconds then start it back up & put it in drive, the temp would go back to normal. I sofar have replaced the thermostat & the thermoswitch also flushed the engine, tested the fans (they work). I noticed today that after driving awhile it started to overheat again, but if I turn on the AC the fans come on & the temp goes back to normal. Any adeas?
Thank you
Old 08-11-2005, 08:22 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Sounds like your coolant fan control module took a dump. its under the battery tray... you can see it from under the car. (also checkthe fuses on top of the battery first.)
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
