Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 08-10-2005, 06:50 PM
L.T. L.T. is offline
Send a message via AIM to L.T.
2000 Grand Marquis cold start problem
When I first start the car in the mourning it won't Idle, so I hold the throttle open until I hear a pop (like a vacuum diaphragm sucking in) after that it idles fine and runs good. After the engine cools back to cold state the problems comes back. I do not have the problem when the engine is hot.
My brother told me he was having the same problem with his Ford Thunderbird. Both automobiles have the 4.6 v8.
It seems to be a common problem.
I have changed the fuel filter, idle air motor, fuel pressure regulator.
I changed the fuel pressure regulator because the regulator would not hold pressure after the engine was turned off. It now holds 40 psi for an extended period of time. It also pressurizes to 40 psi when activated with the key it run position. It is now getting worse.
This problem is intermittent some time it starts and runs fine at cold start.
I have been chasing this problem for almost a year.
Has anybody else had this problem and found out what causes it.
I have fixed this problem!
It is the "idle air motor" it regulates the air flow to the throttle body. I fixed it buy soaking the mechanical end of the part in carberator cleaner.
Do NOT to put the electrical end in the cleaner.
The car has it's horsepower back and starts and idles great.
thanks for all suggestions.
Tom
Old 08-11-2005, 09:00 AM
jimmytroanoke jimmytroanoke is offline
Re: 2000 Grand Marquis cold start problem
Try to find the source fo this vacuum diaphram thing. Maybe a sticking brake booster? Disconnect and plug the vacuum hose at the booster before staring the car and see if that makes a difference. Could also be a bad vacuum reservoir for the HVAC. Disconnect and plug that and see if that makes a difference. Intermittents can be a bitch though! good luck!
2001 Grand Prix SE 3.1 - Someone elses problem now!
95 Grand Marquis - Will outlive all of them!
97 F-150
2004 Toyota Avalon
