Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
View Poll Results: is my car dead??
yes it is in delta heaven 0 0%
no, the beast lives!! 4 100.00%
Voters: 4. You may not vote on this poll
Old 08-10-2005, 05:21 PM
borggirl borggirl is offline
is my delta finally dead??
i have a 1989 delta 88 and it has 222,000 miles. for some reason it likes to stall as im driving down the road. usually when i take my foot off the gas. i have changed the sparkplugs and wires, new starter, new altornator new battery, new fuel pump, new fuel injectors.
when i pull codes all i get is a bad cam sensor (it threw its magnet).
was jsut wondering if anyone had any idea what could be the problem. ive even taken it to the mechanic and they thought it was the fuel pump so i put the 300 bucks into it and replaced it myslef....still doent like to stay running and sometimes wont start. acts like it isnt getting enough gas. never sputters just cuts out....
Old 08-10-2005, 10:47 PM
Hansnet's Avatar
Hansnet Hansnet is offline
Re: is my delta finally dead??
did you fix the cam magnet? how is the TPS voltage?
Old 08-10-2005, 10:48 PM
Jim Adams Jim Adams is offline
did you change the cam sensor??
Old 08-11-2005, 12:17 AM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
That sounds exactly like the problem i am having with my car. Try to test your coil packs and/or ignition module.
You can test the coils by removing the spark plug wire on each coil while the engine is running (just have a buddy ride the accelerator so the car wont die). If the post on the coil doesn't spark or arcs to the side then it is dead....should solve your problem for about $75 to $150 bucks
good luck
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 08-21-2005, 10:39 PM
89 T 89 T is offline
Send a message via ICQ to 89 T Send a message via AIM to 89 T
First post, hello everyone.
I'm having this exact problem with my car right now... code 41. We replaced the cam position sensor and my friend had a revelation... the cam magnet has shredded inside the timing cover. It must be replaced or you will get crappy gas milage (I went from 350 to 270 a tank), boggy throttle response, and rough starts.
The part itself is fairly cheap... it's the labor that's gonna kill you. The timing cover must come off, and the book shows that as 3+ hours. Now, if you're planning on keeping the car, consider also replacing the following since the area will already be exposed:
timing chain
timing chain tensioner
cam button
All the parts together should be $60-$80 if you don't go to the dealer. The repairs will be this week, I can reply later with the results.
Old 10-13-2005, 07:47 PM
ClaytonGraham ClaytonGraham is offline
Send a message via Yahoo to ClaytonGraham
my eighty eight does something but mine sits there and reves high then back down (especially when im at a stop sign) then after a sec it will die but i start it right back up i have replaced the plugs plug wires and alternator
Old 11-07-2005, 08:30 PM
vamc's Avatar
vamc vamc is offline
what about changing your pcv valve?
