Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 08-10-2005, 04:40 PM
Wubs Wubs is offline
Question New key programming
Hi.
I searched and could not find this posted before: If I buy a key off of eBay, how do I program it to be accepted by my 2002 Montana?
I'm dense, so I'll explain: I only have one original key (it has the "chip" in it to prevent theft). I want to buy a key from eBay as it cost $50 from the dealer here in Canada and another $50 to program it.
Can I do it myself? If so, what is the link for the instructions? (same for another remote keyless fob I need to buy, please).
Thanks in advance to anyone who takes pity on me and replies!
-Wubs
Old 08-11-2005, 06:29 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Do you already have the remotes? If not, check out the link in my sig...they seem to have all the Montana remotes and should be able to help.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 08-11-2005, 07:00 PM
Re: New key programming
It's NOT the remote FOB programming instructions I am looking for.
I am looking for info on how to program a PK3 key.
Thanks
Old 08-11-2005, 07:08 PM
sharo23 sharo23 is offline
Send a message via AIM to sharo23 Send a message via Yahoo to sharo23
Originally Posted by Wubs
Hi.
-Wubs
all gm cars has a master key you need to have it most of them it's the black head one start the car with the master key shut it off and insert the new key with in 5 sec and it should learn the key
Old 11-10-2005, 07:06 PM
BETTY NAPIER BETTY NAPIER is offline
Re: Re: New key programming
THE NEW KEY MUST BE TURNED TO THE ON POSITION WITHIN 10 SECONDS AFTER REMOVING THE ORIGINAL KEY AND THEN REMOVED AFTER LEAVING IT IN THE ON POSITION FOR AT LEAST 5 SECONDS. OTHER NEW KEYS CAN BE PROGRAMMED THE SAME WAY.
Old 11-10-2005, 10:19 PM
Actually, through my research I have discovered that in Canada and Europe, the insurance companies have forced GM to make it so that there MUST be two pre-programmed keys BEFORE any additional keys can be programmed.
This is to prevent easy duplication by theives (it makes sense to me, read on to see why).
To program additional keys when you only have ONE key, the GM dealer uses that programming tool they have to erase this setting from the BCM. Then they program the second key; then use their tool to add the deleted setting back in to prevent a thief from programming any additional keys using only one master key.
Here is the rationale: some cars are stolen after a parking valet or mechanic has one key, they could get a second blank key, cut it to match the one master key, program it and then steal your car days later so you wouldn't think that they had anything to do with it.
Probably not a common scenario, but one that made the insurance companies worry enough that GM did it this way.
So, only in the USA do you need one key before you can program a second key.
Every where else, you need 2 keys, or go to a dealer and pay lots of money.
Old 11-20-2005, 05:57 PM
bobbuell bobbuell is offline
is the programming of a spare key different if you have to have 2 keys, if i do it myself?
Old 11-20-2005, 08:27 PM
If you already have two working keys for your Montana/Venture/Shilouette, then you can program additional keys as per the owner's manual.
In the USA you only need to have one working key.
In Canada, Europe & Japan, you need to have 2 working keys.
-James
Old 11-22-2006, 02:26 PM
BIGPROFITT BIGPROFITT is offline
Send a message via Yahoo to BIGPROFITT
How can I tell if my van came from the US or Canada? Just want to make sure before I get started.
Old 11-22-2006, 03:02 PM
maxwedge maxwedge is offline
A990 racer
Look at the VIN, if it starts with a 2 it is Canadian.
Old 11-22-2006, 03:20 PM
travist's Avatar
travist travist is offline
Mileage will be in km, not miles if it was fmade in Canada.
