Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 08-10-2005, 04:17 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
1997 Sentra GXE Check engine light
My friend has a 97 Sentra GXE 1.6. Is there any way to turn the SES light off other then with a scanner? I have access to a scan tool but he has to drive 45mins to my house every time so that i can reset it. Just wanted to know if there was any other way to reset the light. I tried pulling the ecm fuse but that did nothing. It comes on because of an EGR malfuction(Code=PO400) but he does not want to fix it right now. Any help/segestions would be appriciated.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 08-10-2005, 04:26 PM
Andrewh Andrewh is offline
Re: 1997 Sentra GXE Check engine light
Howabout an autozone near by? They have scanners they use for free. Also you can rent one from them. Or if he is going to ignore it, just put tape over the light.
Old 08-10-2005, 09:17 PM
ZL1power69's Avatar
GM S-Series Mod
neither of us live near an autozone. as i said i have access to a scan tool but its a pain in the ass for him to drive 45mins to my house just to reset the light. i reset it again today. you can't just ignore the light. his was on for a month prior to today and it put the car in loop mode which will hapen if you just ignore the light. loop mode causes the car to lose performance which is why i reset it today. all i want to know is there any way to reset the light without a scan tool, something he can do himself.
Low 11 sec sleeper
My Cardomain
Old 08-12-2005, 01:04 AM
slideways...'s Avatar
slideways... slideways... is offline
try disconnecting the battery. if that doesnt work, then nothing will
i dont know why you even want to turn it off...it will keep popping on again until you fix the issue. and with a CE light why would you care about abusing your car anyways? just calm down and fix the problem, then go back to racing or whatever you need the power for
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 08-12-2005, 09:47 AM
ZL1power69's Avatar
GM S-Series Mod
Re: Re: 1997 Sentra GXE Check engine light
[quote=slideways...]try disconnecting the battery. if that doesnt work, then nothing will
i dont know why you even want to turn it off...it will keep popping on again until you fix the issue. and with a CE light why would you care about abusing your car anyways? just calm down and fix the problem, then go back to racing or whatever you need the power for[/Q
lets get this straight, Its not my car! im just trying to help my friend out. code that comes up is PO400 which is EGR malfuction. When i replace his cat i'll pull the egr and see if its clogged. And buy the way the car is stock and he does not race. he needs the light off because with the engine in loop mode he has no power and when he took a high speed onramp,he almost got run over.
Low 11 sec sleeper
My Cardomain
Old 08-12-2005, 02:35 PM
Right, got that. But as I said, if he can afford the temporary lay out of cash, autozone rents out scan tools so he can reset it himself. It is a 1 time trip till he fixes it, then he can return it.
Old 08-14-2005, 09:21 PM
ZL1power69's Avatar
GM S-Series Mod
whats the point if he can use that cash toward a new EGR? Sucks that you can't just pull a fuse of something like that to reset the SES, like my jimmy. Anyway I thank everyone for the comments.
Low 11 sec sleeper
My Cardomain
Old 08-15-2005, 01:34 PM
He can still use the money to fix the egr. It is a deposit. When he returns the tool, he gets all the money back.
