Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 08-10-2005, 04:02 PM
cazels1 cazels1 is offline
A/c Compressor
I have a 1995 olds aurora and when i turn on my a/c it sounds rough so i put in a can of quick charge refrigerant thinking that would cure the problem but it didnt. a/c does blow cool air. oh and when it rains hard my power steering goes out for a few minutes and my dic says check charge system but everything is good no leaks in power steering or anywhere and there is a brand new serpintine belt on the car. Please help or respond with any info
Old 08-10-2005, 08:40 PM
zimaad zimaad is offline
Hey there,
The 3 different problems you describe could possibly be related. You describe 1)a noisy compressor 2)loss of power steering and 3)not getting charge on system/faulty alternator. All of those things are on the same belt/pulley system and therefore are driven by the serpentine belt/crank pulley. I'd check out the belt and all of the pulleys it connects, starting with the compressor since you hear noises there. Also, if you can, check the low and high side pressures in the A/C system(need manifold guages to do this...or maybe just low side w/a 134a refil kit). That info can give you a clue to system operability.
good luck - Drew
Old 08-12-2005, 08:45 AM
a/c compressor
i put a new belt on so the belt is good. the compressor is only loud when on.the low side is at 50psi dont know what high is at. how do i put oil in the compressor? oh and im missing the wheel splash guard could this make a diff?
Old 08-23-2005, 02:03 AM
zephram22's Avatar
zephram22 zephram22 is offline
Send a message via AIM to zephram22 Send a message via Yahoo to zephram22
Hope it all works ouit for you.
1963 Triumph TR3 12K
1995 Buick Century Special 178K
1999 Chevy Lumina LTZ 160K
2001 Suburu Forester 53K
2002 Oldsmobile Aurora 3.5 45K
2004 BMW Z8 3K
2005 Dodge Charger .5K
2006 Jaguar XJ12 1K
