Old 08-10-2005, 03:24 PM
Squirr3l Squirr3l is offline
Send a message via AIM to Squirr3l
GS-T Caliper questions...
Hey guys, sorry I haven't posted in a while, just been doing a bit of work to my Eclipse. I've run into a decision making problem tho and I wanted some input if u could spare. I was wondering what's the big diffrence (if any) is between the 2nd gen Eclipse GS calipers and the GS-T calipers. Also if its difficult at all to swap the GS's calipers with the GS-T's. I wanna keep the stock 5-spoke aluminum wheels but i want more stopping power and every brake upgrade kit I see has oversized calipers, which means I have to upgrade from the 16" rims. So I was thinking about swapping my calipers with the GS-T ones if it provided any kinda advantage. Thanks a lot guys.
~Squirr3l
Old 08-10-2005, 05:00 PM
TreeFrog's Avatar
TreeFrog TreeFrog is offline
Send a message via AIM to TreeFrog
Re: GS-T Caliper questions...
not sure the difference there, but try putting on Rear gs-t calipers and replace your rear drums. that will help a bit, and i've seen it done
Something new is coming...
Old 08-10-2005, 10:30 PM
Black97GST Black97GST is offline
do the GSs have drum brakes? i thought all Eclipses had 4 wheel disc brakes? hmmmm..... maybe not i dont know??
Old 08-10-2005, 10:40 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
Re: Re: GS-T Caliper questions...
as far as i know, only rs come with drums in the back, then the rest with brake disc,
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 08-10-2005, 10:41 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
its really weird in the back, i think it has the drums and disc brake, maybe im wrong or i was seeing things
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 08-10-2005, 10:47 PM
Re: Re: Re: GS-T Caliper questions...
maybe thats what Im thinking
Old 08-10-2005, 10:50 PM
noooo you wouldnt have both, not to make you sound dumb so dont take offense to this b/c im just trying to help, but do you know what rotors are?? maybe thats what you are mistaking for the drum brakes. the calipers are what "clamp" onto the rotor, which makes the car stop
Old 08-10-2005, 11:31 PM
maybe it wasnt a drum then, i remember seeing calipers, this was a while ago so i cant quite remember
95 Eclipse GS-T
Currently:
Soon lol
Old 08-11-2005, 12:09 AM
It goes as follows, 2nd Gen Eclipses: RS=disc/drum GS=disc/disc GS-T=disc/disc GS-X=disc/disc and then like the GS Spyders have a disc/drum set up but who cares lol. Anyways, so yea I have a GS and is has disc in the front and rear and I was wondering if my calipers were any diffrent from the GS-T calipers.
Old 08-11-2005, 12:55 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Some cars have both. Some cars use a small drum within the rotor as an emergency brake. I know the 300zx has this set-up not sure if the 2g do but i know the 1gs don't. As for the calipers i wouldn't think there is much difference, if any. Unless the gs-t's have two piston calipers which i' pretty sure they don't. Why would you need upgraded brakes on a gs anyway j/p.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 08-11-2005, 01:04 AM
yeah but the discs for the emergency brake wouldnt be visible
Old 08-11-2005, 01:07 AM
ez1286's Avatar
True but its the drum thats for the e-brake.
Old 08-11-2005, 01:13 AM
oic
Old 08-11-2005, 01:23 AM
ez1286's Avatar
I just thought of this... Have you ever heard of cryo treating? My brother just had his internals cryoed and they sent us tons of info on it. Anyway there was something about ambulances having their rotors cryoed (i was like wtf at frst too) what this does is aligns the molecules providing more surface area for the pad to contact. I don't have the broshure with me now but i know it was omething like a 20% increase in braking. It is also really cheap (we used a place called 300below). I plan on having my new turbo cryoed.
Old 08-11-2005, 10:47 AM
Gsx_hooptie Gsx_hooptie is offline
The gsx has two piston calipers up front, the others are single. I believe the gsx, gst, and gs all have the same rear brake assembly.
I used to own a DSM.
Originally Posted by Anon.
Capitalization is the difference between, "Helping your uncle Jack off a horse," and, "Helping your uncle jack off a horse." The comma is the difference between, "Eats shoots and leaves," and "Eats, shoots, and leaves."
