Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 08-10-2005, 03:13 PM
sierra61 sierra61 is offline
Question no engine check light, no spark no fuel pump
hi, i just have a 95 stratus v6 it was perfect has only 45,000 miles ,the ignition was broken so ihad to replaced , one when i was driving then suddenly it stop, then it started again and run a few miles then stop again. and since it don't start it cranks, but the car didn't start. the check engine light is off even when i open the key.then i checked the fuel pump and it didn't have any spark, i checked the fuses and relays and their ok.i changed the coil pack, check the spark wire and no spark. the day before it had a problem with the transmission because the oil level was over it. it took some oil out, then the car was working fine. i'm sorry if you can't understand what i wrote. but i don't know how to explain it better. but i really need your help, i'll be very grateful if anyone could help me.. i really need your help!!! thanks
Old 08-10-2005, 09:56 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: no engine check light, no spark no fuel pump
sounds like your ASD relay have tripped. Try swapping it with your A/C relay and see what happens.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 08-11-2005, 01:57 PM
Thank's Do You Know Where Is Locate It
Old 08-11-2005, 09:43 PM
it's in your underhood fuse box called th power distribution center.
Old 08-14-2005, 12:41 PM
still not working
Old 08-15-2005, 08:45 PM
i think the problem is the computer , do you know if have to be from the same year and the same car ? because i put one from a 96 and the car start but went off again . please help
a.s.a.p
thank's
