Old 08-10-2005, 12:00 PM
coach65 coach65 is offline
Hub assembly
I need a new hub assembly for my 97 grand prix for the front passenger side. How difficult is this to put on? I would like to do this myself but have never messed with anything like this before. Is there a site that describes the steps?
Old 08-11-2005, 08:00 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Hub assembly
I don't know of any site that has instructions but it can be a DIY job. The major obstacle to replacing the hub will be getting the axle shaft nut off and then torquing it down upon completion which is 151 ft-lbs.
You'll probably have to rent special tools such as the large socket, breaker bar to get leverage, and torque wrench. Good luck!
Thrasher CAI, DHP v1.0 PCM,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 TB,
TB spacer, MSD 8.5mm wires, Autolite 104s,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
Timeslip 08/12/06
AF Community Guidelines
Old 08-11-2005, 08:09 AM
ctesla's Avatar
ctesla ctesla is offline
I think that axle nut is like a 31 or a 35mm.
Old 08-11-2005, 08:52 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Hub assembly
a hub is definitely a DIY job. IF you can do brakes, you can do a hub. Buy a repair manual, so you have the proper torque specs, and read the literature that comes with the replacement hub. IF the replacement hub specifies a different torque than teh repair manual, use the spec that comes with the hub bearing. Changes in design of the bearing can affect the torque for proper bearing pre-load. The #1 MOST important thing to remember is to avoid using impact tools, as the vibration they create can damage the ABS sensor contained in the hub. Use hand tools only and torque everything to spec, and you shouldn't have any problems. Also, clean the mounting surface between the hub and the spindle of rust or dirt.
Old 08-11-2005, 09:48 AM
BNaylor's Avatar
Re: Re: Hub assembly
Personally, I wouldn't classify doing a hub and bearing assembly in the category of brakes. Brakes are a lot easier with simple hand tools.
If you decide to tackle the job yourself and if you are having problem getting the hub and bearing assembly off, you will need a Front Hub Spindle Remover to force the axle away from the hub. Its GM Part number (J-28733-A) or equivalent. Good luck!
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
Timeslip 08/12/06
Old 08-11-2005, 10:59 AM
richtazz's Avatar
Re: Hub assembly
what I was getting at is the proceedures aren't difficult, and if you have the mechanical ability to do your own brakes, you can do your own hub. Yes it does require some special tools, but you can rent them for free at some "box" stores.
Old 08-11-2005, 11:40 AM
BNaylor's Avatar
It's OK you can name those "box" stores.
Free tool renting yes but only after the hassle of a security deposit in which you'll get back as long as you bring the tool back in one piece. Thats my experience with Autozone, etc.
Timeslip 08/12/06
