Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 08-10-2005, 11:01 AM
Suburban-97's Avatar
Suburban-97 Suburban-97 is offline
Question Idle RPMs
My truck runs at about 650rpm at idle when warm. My wife's car runs at 800rpm, but hers is a 4Cyl. At 650 the engine runs absolutely smooth, I actually do not worry about anything, but I was just wondering whether 650 is the normal number I should see or not..
1997 CHEVY SUBURBAN LT
5.7L Gasoline, K1500 4x4
Old 08-10-2005, 12:26 PM
MIkeman28 MIkeman28 is offline
Re: Idle RPMs
I run at 850. I wouldnt compare toa 4cyl tho. If it works good, dont fix it
Old 08-10-2005, 01:18 PM
Re: Idle RPMs
MIkeman28, after doing a little browsing on the 'Automotive Repair Reference Center' website at the library, I found a document containing the gasoline engine tune-up specs for K1500 Suburbans from 1996-2000. Among spark plug gaps and fuel pump pressures, there are the idle speed rpm values.
Here they are:
(VIN W) 4.3L - 600 rpm
(VIN V) 4.8L - Idle speed is maintained by the PCM
(VIN M) 5.0L - 650 rpm
(VIN T) 5.3L - Idle speed is maintained by the PCM
(VIN R) 5.7L - 660 rpm
(VIN U) 6.0L - Idle speed is maintained by the PCM
(VIN J) 7.4L - 750 rpm
..so I guess mine runs like it should and yours is a little too high at 850
Old 08-10-2005, 01:58 PM
Re: Idle RPMs
true. But like I said, idle at 850 is not doing any harm, so no need to fix anything. Anything over that and I would probably check my intake gasket
