Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-10-2005, 05:55 AM
Dave_M Dave_M is offline
94 Caprice-antilock brake issue
I have a 94 Caprice Classic (125,000 mi.) and the antilock brake light has been on for awhile. It still stops, so I wasn't too concerned, but last winter it was obvious that the anti-lock feature wasn't working. (I live in western NY)
I had to take it to my mechanic for somthing else and I asked him to check into that. He said that "there's probably a piece of dirt in the valve assembly for the antilock brakes" and it's not repairable. According to him it's about a $500 part and I'm not about to spend that kind of money on this car.
I have always changed my own brakes because it's an easy way to save $$. When I told him that I changed my own brakes by simply prying the caliber apart with a big screwdriver to get the old pads out (as taught by my father) he said that's probably how I damaged it.
2 questions:
First, does my mechanic's explanation make sense? (I had changed front brakes on that car several times previously with no issues)
Second, I seem to have read someplace that there's a wheel sensor associated with anti-lock brakes that can get boogered up by rust and that can cause this symptom. Any truth to this?
Thanks...any input will be appreciated.
Old 08-10-2005, 06:03 AM
CD Smalley CD Smalley is offline
Re: 94 Caprice-antilock brake issue
You're on the right track with the wheel sensor. You need to get the codes from the ABS unit first before you start throwing parts at the thing though. I can't help with that. But google can I am sure....
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 08-10-2005, 07:29 AM
Thanks CD!
Do you happen to know what type ABS system the Caprice has? (4 channel, 3 channel or 1 channel)
I would suspect 4 channel, but just don't know.
Old 08-10-2005, 07:39 PM
3 channel if you are referring to how many sensors it has.
There are one for each front wheel and one for the rears. The rears are run from the pinion gear.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 08-10-2005, 09:21 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
yes it is 3 channel i think, for codes ask formulalt1, i think he can help
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
