Old 08-10-2005, 05:12 AM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Physics question
I posted this in the Firebird forum, but figure I'd repost it here as well since I'd probably get more answers from you guys. So here it goes...
Ok, I recently found on GMgoodwrench.com an alloy engine. No idea on the price, it wasn't listed, but I wanted to get some opinions before I even bothered with the idea. It's V6, 60 degree block, just like my 3.4. The specs on it are as follows:
"Aluminum Bow Tie V6/60º engine blocks have rough-bored 89mm (3.504") cylinders which can be safely overbored to 91mm (3.582"). Light alloy Bow Tie blocks have bosses for both front-wheel-drive and rear-wheel-drive engine mounts. The starter motor can be installed on either side of the block. The cylinder walls are non-siaesed, and the cylinder deck height is 8.820". Cylinder bore range is 3.525-3.582"; crankshaft journal diameter is 2.65"; all sump type is wet. This block has a 2-piece crankshaft seal and a design maximum stroke of 3.20". Intended for professional competition."
Summed up:
Bore: 89mm, can be safely bored to 91mm (3.525"-3.582")
Max Stroke: 3.20"
Total ci: 185ci (3.05L)
Total ci (bored to max 91mm): 193.4ci (3.18L)
Now, my 3.4L specs:
Bore: 92mm (or 3.62")
Stroke: 3.31"
Total ci: 204.3 (3.37L)
So, if I were to go with this new alloy block, I would be shedding 47lbs.. And if I were to have the block bored out to it's maximum 91mm, I would still be losing 10.9ci (0.19L). Now, as most of you know, I'm really gung ho on doing this 3.4L project. So, what I ask now, is do you think that going with a smaller block and losing 10.9ci is a smart idea? Again, I would have an overall benefit from having a 59lb alloy block rather than my 106lb cast iron one. But, I hate the thought of having a smaller and bored out 3.2L. Opinions? What would you do? Do you think the lightness would make up for the smaller size and give me overall more power?
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 08-10-2005, 05:50 AM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
I say go for it, I mean hey if you're going to bore it out and do a bunch of stuff to the engine, it sounds good. I do think though that with the loss of pounds and size of the engine you would basicly get the same output of your old one.
Old 08-10-2005, 06:24 AM
blindeyed's Avatar
eBay aDdict™
Re: Physics question
Yeah, that's what I was afraid of. I mean, basically I would be downsizing .2L's, but also cutting my weight in half. So I'm not sure if I would basically be compensating weight for power, and end up right back where I started with around 160HP. But it couldn't be too much different though. A stock 3.1L puts out 150hp w/ ~180tq. Sooo, a 3.2L alloy block should be making a little, if not alot more than those numbers.. But again, that would just put me right back where I already am right now.
- Jason
Old 08-10-2005, 06:26 AM
Is eating.
Well im sure it would help on the gas.. a little, also you could do different stuff to this engine and its newer so I think that those are both over the old engine
Old 08-10-2005, 06:31 AM
blindeyed's Avatar
eBay aDdict™
yeah, debating on the price, I may or may not get it. If it's reasonable, then I'll probably build it up and see what I can get out of it. If I don't see any improvement, then no biggie. I've got this really wicked plan of getting a Miata and popping a 3.4 in it. Which, the alloy one would be perfect since it would actually be lighter than the 4cyl that comes in it. That, and then get a custom hood made with the SS scoop on it, and that would be one sick and extremely fast Miata. One day I'm gonna do that.
- Jason
Old 08-10-2005, 06:35 AM
Viper_Storm's Avatar
Viper_Storm Viper_Storm is offline
Send a message via AIM to Viper_Storm Send a message via MSN to Viper_Storm
i say its not really worth it, you may shed some lbs but you lose power to, so its prob gonna end up being the same.
All Throttle, No Bottle!
Torque Makes You Go... FAST!
Horsepower Is For Braggin Rights.
Money talks, But all mine ever says is Goodbye
~Viper
"twospirts" / "TS" - Definition: Obsolete
Old 08-10-2005, 06:38 AM
Is eating.
Re: Re: Physics question
Kinda.. late there..
About the Miata thing, DO IT! Be so badass and unexpected.. and add some turbo if you can.
Old 08-10-2005, 06:51 AM
Re: Re: Re: Physics question
yea, that would be hot.
~Viper
Old 08-10-2005, 06:57 AM
blindeyed's Avatar
eBay aDdict™
Yeah, this one guy I know built up a 3.4, turbo'd it and put it in a miata. only custom things he had to have done were motor mounts, a shorter driveshaft, and the hood. and for the rearend, he used a Ford 9 bolt since it bolted up perfectly. As for the engine and tranny, well, they lined up perfectly and fit like a charm. Man is that thing sick. Here's a link to his site:
http://34v6miata.tripod.com/
- Jason
Old 08-10-2005, 07:03 AM
that miata is nice as hell, altho id have to sit in the back seat to be able to drive it. be like that dude hightower from the movie police accademy.
~Viper
Old 08-10-2005, 07:15 AM
Is eating.
Miatas dont have back seats..
the idea of a V8 in a Miata btw is SICK!
Old 08-10-2005, 07:19 AM
i will have to sit on the trunk lid then
~Viper
Old 08-10-2005, 07:20 AM
Is eating.
Lol im not sure i'd fit in a Miata, I always drive with the seat all the way back too! So who knows..
Old 08-10-2005, 08:21 AM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
I think it would depend more on what kind of HP the engine puts out. You don't say anything about that as I'm sure goodwrench didn't either, it really depends on what it puts out. It may be a smaller displacement engine but it may have higher compression and more horsepower than the 3.4L That is why there are 4 cylinder cars that have like 150 HP. I say figure that out and then debate it.
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 08-10-2005, 08:27 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
If I got an LS1 it would be the same weight as my 3.8, have 219 more ci, and a hell of a lot of more power...
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
