Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 08-10-2005, 02:39 AM
mizzle519 mizzle519 is offline
Misfire under hard acceleration?
I have an 89 supra turbo. lately under hard accel i have been getting some bad misfire and loss of power.. one guy on the street said he saw sparks coming from my exhaust when it was misfiring.
the car is somewhat modified and had little problem up until recently
it also doesnt seem to misfire under 10psi of boost but about 12-14psi at higher rpms causes bad misfire. any ideas?
Old 08-24-2005, 04:10 PM
GadflyII's Avatar
GadflyII GadflyII is offline
Re: Misfire under hard acceleration?
Do you have a Wideband o2 in the car? What are your A/F ratio's when it misfires? What plugs are you running?
your air fuel might be off, but more likely it is your plugs. Try running a hotter plug. In MKIV's we run NGK 3330's, you can pick them up at www.boostlogic.com for a good price.
Ron
94 Supra Turbo 6spd
Ported head w/ 1mm over sized valves
6pt cage w/ removable door bars
SP67 Single Turbo .81 A/R
RPS Manifold
SP fuel sys w/ 1000cc injectors, SP rail, & Dual Walboro pumps
Aeromotive FP regulator
Greddy 3 Row front mount
Tail BOV
TRD Rear Diff
TRD dual disk clutch
HKS Racing Wastegate
HKS DLI
HKS VPC
HKS BCC
HKS EBC
FJO Wideband o2
Greddy Electronic Boost, EGT, Fuel pressure w/ Peak & hold
98 tail and headlights
Wings West lip
Old 10-20-2005, 09:37 AM
cp1's Avatar
cp1 cp1 is offline
when this happens does your "engine" light flash on and stay for a second or two? if so, your most likely hitting fuel cut-off which is a toyota computer controlled measure which actually turns off your fuel so you dont detonate and wreck your engine, if your car is modified what have you done to it? if you put a bigger turbo in or changed your afm then your car is recieving a lot more air than should and with stock injectors your fuel system cant keep up.
