Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 08-10-2005, 12:24 AM
DjEarth DjEarth is offline
Ignition Question
So we did the spark plugs/wires/cap/rotor tonight..just got finished actually. I don't think the plugs have ever been done they were pretty bad..anyways.
So we go for a little drive just now..and notice that when stopped at the lights the veichle is idling quite rough..almost like it is gonna die out..but then drives away fine.
Then I shut it off..went to start up again and it died once..then turned over.
Could this be somthing as simple as the cap or rotor arent tight enough..or one of the wires isn't on tight enough?
99 LS 4x4..replaced with NGK plats and MSD wires.
Old 08-10-2005, 12:51 AM
Russian Blazer Russian Blazer is offline
Change air filter, check fuel filter, make sure that all sparks and wires are inserted correctly. Try to change the Knock sensor and see what happens.
Old 08-10-2005, 12:52 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Ignition Question
Did you put the wires on right? It is a common mistake to put 1 and 3 in the wrong spot on the cap.
Old 08-10-2005, 01:15 AM
Air and fuel filter are new.
Hmm pretty sure we put them on right..but will definatly double check tomorrow. Too tired and dark out now.
Old 08-10-2005, 01:22 AM
I am on the other side of the glob. In Moscow it is now 10.22 am
Now i'm driving Blazer, but i'm planning to buy a tank.
Old 08-10-2005, 01:52 AM
blazee's Avatar
Problem?
Old 08-10-2005, 08:15 AM
New issue.
Haven't checked anything yet, just woke up to take the GF to work..and I got a orange light on the dash in the top left coronor..looks like the motor symbol. Obviosuly that isn't good.
If we had misplaced one of the wires would this cause that light?
Im startin to freak out a little now.
That is the same guide we used Blazee..but like I said we haven't checked yet.
Old 08-16-2005, 10:58 AM
So after a week of running rough we finally got it figured out.
One of the spark plugs we put it..was faulty. Had to have been from the package..or got cracked when putting it in.
the rear one on the passangers side. Replaced it. Engine is running smoother then it ever has.
Old 07-25-2006, 11:56 PM
blazin911 blazin911 is offline
remember passenger side plugs are 246 and driver side are 135 and on the cap the passenger side correspondes with 246 also but the driver side is 315 hope this helps
Old 07-26-2006, 05:54 AM
blazee's Avatar
Problem?
His last post said that the problem was solved a year ago.
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
Closed Thread
