Old 08-09-2005, 10:54 PM
rbi99 rbi99 is offline
Wipers park straight up
My 97 GT wipers park in the up position. They are tight on the cam, and correctly situated. When you turn them off they go to the down position for a sec, then move up straight and park there. Other than that they work fine. I have seen at least four other Grand Prixs in town with the same problem.
Old 08-10-2005, 08:08 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Wipers park straight up
You could have a problem with the wiper motor reverse or at home position or try this old GP forum link that may be helpful:
http://www.automotiveforums.com/vbul...ght=wiper+park
Good luck!
BTW - Welcome to the forum.
Thrasher CAI, DHP v1.0 PCM,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 TB,
TB spacer, MSD 8.5mm wires, Autolite 104s,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
Timeslip 08/12/06
AF Community Guidelines
Old 09-02-2005, 07:00 PM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
In case you have not found out by now, there's a recall for 97 GP wiper problems.
Old 09-03-2005, 08:30 AM
Working Now
Thanks for the input. I fixed them by bending that metal piece on the wiper motor back up to 90 degrees. As for the recall I went online at Consumer Reports but they didn't show a recall for that - but I will call them about it now - Thanks again!!
Old 09-03-2005, 11:24 AM
There's definately a recall on the these wipers because I own a 97 GP GT and had the work done for free at a dealership. I don't know about the GPT's, your local Pontiac dealer could tell you one way or another.
Old 09-03-2005, 03:08 PM
BNaylor's Avatar
You're correct. There was a recall on certain 1997 Grand Prixs. See data below. My '97.5 GTP was manufactured after 05/97 and I never received a recall notice. The best thing to do is call Pontiac Customer Service, give them the VIN and they will let you know if you qualify.
NHTSA Campaign ID: 99V348000
Component: Visual Systems:Windshield Wiper Linkage Pivot Drive Assembly
Manufacturer: General Motors Corp
Year:
1997 Make:
Pontiac Model:
Grand Prix Recall Date:
03/25/2002
Potential Number of Units Affected: 155149
Manufactured: 03/1996 - 05/1997
Defect Summary:
The windshield wipers may stop working due to a separation between the drive pin and crescent in the crank arm assembly.
Consequence Summary:
Driver visibility could be reduced, increasing the risk of a crash.
Corrective Summary:
Dealers will inspect these vehicles for the presence of a plastic water deflector and, if necessary, replace the wiper motor crank arm and install a water deflector. On vehicles receiving a replacement crank arm and new water deflector, dealers will also apply additional sealing material to improve water deflection away from the crank arm assembly and will install a reinforcement to improve the performance of the wiper park mechanism.
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
Timeslip 08/12/06
