Originally Posted by osu1978
Ok guys I really need some help here as I am at a loss. Everything runs great on this car but it stalls on me once a week. This happens at any speed and when idling or steady driving; never when accelerating. MAF replaced, computer replaced, fuel pump and relay pass tests. Grounds have been checked.
After stalling, I can usually start it up in neutral or if I pull over and put her in park, but sometimes restarting can take a couple minutes. Occaisonally it takes a few cranks to cold start but seems to have more problems hot starting.
At this point, what do you think the culprit is? I will probably be replacing one or two more things and if they do not fix the problem I will purchase a new car. This is the non-supercharged version.
Thanks
dude i have the same make and year 1995 olds lss and it started stalling on me too, everything else is great, i replaced everything, alternator,battery, sparkplugs, pcv, air and oil filters trannie filters new trannie fluind oil change , flushed radiator added new fluid, blew out my air intake manifold and still got the darn stalls, and no check engine light, when i slow down or make a turn going slow the car just shuts off, but my radio and everything esle remains on, i think those guys are right about the crank case sensor, thats the only thing i did not change, it is located behind the harmonic balance pully which i can't get off, it has a 15/16th bolt that is a b_t_h to get off, i broke my SK pry bar trying to get the bolt off, i am going to my brotherin laws shop on sat to use his 650 pound torque air gun to get the bolt off, the sensor is right behind it , i will let you know how i made out on sunday because i think it will be an all nighter, if i can save some one the misery i went through it will be worth it. p.s. my security light on the dash came on once or twice the first coulple of stalls, but no more since i did all the other crap listed above, good luck dude, the car rides like a dream that is why i am trying to save its life,let you know the deal sunday night peace out
