1990 Buick LaSabre Light Bulb
Can someone please tell me how I can replace the light bulb that went out in the speedometer of my 1990 Buick LaSabre?
Re: 1990 Buick LaSabre Light Bulb
Take the dash apart and remove the instrument cluster to replace the bulb in question. It's tedious but if you have the time it not complicated.
I had to replace my lights in my 90 Lesaber. To remove the dash, there are six or so screws along the front face AND two screws are in the defroster vents. You need to pry up a plastic vent to get at these. Once the dash is off, the instrumentation cluster unit is held on with four screws and comes off by pulling straight back.
The light bulbs holders simply twist on-off. The speedometer lights are the six bulbs along the bottom. You can reuse the original holders with replacement bulbs if you can remove the old bulb (the bulb and holder are made as a unit). The original equipment illumination bulbs are blue light bulbs (B196) but you can use the white (196) if need be. The lights should just press into the holder. |
can you tell me what type of tools I need for these screws? do you need special tools? thank you for your help!! I appreciate these instructions. I understand what you're saying, but you might be able to tell by now that I am a girl in need of as much information as possible. thanks again.
I had to replace my lights in my 90 Lesaber. To remove the dash, there are six or so screws along the front face AND two screws are in the defroster vents. You need to pry up a plastic vent to get at these. Once the dash is off, the instrumentation cluster unit is held on with four screws and comes off by pulling straight back. The light bulbs holders simply twist on-off. The speedometer lights are the six bulbs along the bottom. You can reuse the original holders with replacement bulbs if you can remove the old bulb (the bulb and holder are made as a unit). The original equipment illumination bulbs are blue light bulbs (B196) but you can use the white (196) if need be. The lights should just press into the holder.[/quote] |
I don't know if the 90 is the same as a 92 but I posted this a while back and thought that it may be helpful to you.
Dashboard removal procedures: http://www.automotiveforums.com/vbul...d.php?t=429709 |
