93 Taurus Brake Problems
I had no problems with the brakes then one day I applied the brakes and the pedal went to the floor. After pumping a couple times they worked fine. A couple days later the same thing happened. I replaced the master cylinder, rotors and pads. The brake pedal now now seems spongy and goes almost to the floor. There are no leaks anywhere and I bench bled the master cylinder and bled all 4 calipers. The car has 4 wheel disc ABS.
Re: 93 Taurus Brake Problems
Sounds like a bad master cylinder.
Or, pick up a set of Speed Bleeders and replace your bleeder screws. These are well worth the $16 for a set of four and most local parts shops stock them (at least around here - Iowa). Speed Bleeders incorporate a 1-way valve on them. You simply open one a quarter to half a turn, put a hose on it to guide the fluid to a bottle, and slowly pump the brake pedal. The spring loaded bearing will allow fluid to escape under pressure, but when pressure is removed, the spring pushing the ball bearing against the seat and closes the valve so you don't suck air back in to the line. After about five presses of the brake pedal, close the bleeder screw and move to the next caliper. When the Speed Bleeder is closed, they function just like a normal bleeder screw. I think if every DIY'er had Speed Bleeders on their cars, they'd all flush/bleed their brakes annually as recommended! Nope, I have no ties to Speed Bleeder, but I use them an all our cars. They are especially handy on my track car where I change pads at the track and keep the fluid in the system fresh to prevent brake fade. -Rod |
Re: Re: 93 Taurus Brake Problems
It's possible there is air in the ABS unit. There's two ways to go about getting the air out. The 'factory' way is to take it to a shop where they can cycle the ABS unit with the car on the lift. The poor man's way is to get it up to speed and romp on the brakes to engage the ABS (if you can get enough pressure).
How old are the flex/rubber brake lines?
Flex lines deteriorate on the inside. They will internally fail causing blockages that act like one-way valves not allowing the brakes to release.
i'm not sure if you have a brake booster (for assisted braking) but if you do, you might want to check into that as well, it may be leaking internally (vacuum) or possibly frozen (hydraulic). just a thought.
