Old 08-09-2005, 07:16 PM
risingernicole risingernicole is offline
VSS check and replacement
Can someone please tell me exactly where to find the VSS on a 01 Se? And if there is a way to tell if it is bad or not? How much does it cost to replace it?
Old 08-10-2005, 07:13 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: VSS check and replacement
The vehicle speed sensor (VSS) on a 4T65E tranny is located on the transaxle extention housing of the passenger side where the drive shaft is located.
When it goes bad a odb-ii DTC error code is supposed to be generated. The PCM computer uses it to establish shift points and it feeds the speedometer.
GM list price for the VSS sensor is approximately $28.00.
Thrasher CAI, DHP v1.0 PCM,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 TB,
TB spacer, MSD 8.5mm wires, Autolite 104s,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
Timeslip 08/12/06
AF Community Guidelines
