Old 08-09-2005, 06:34 PM
mike01166 mike01166 is offline
93 Blazer/Jimmy 4wd problem
My jimmy is a 4wd. I found out the front wheels werent turning, so we investigated. Broken vaccum hose. We fixed it and 4 hi and low works great now.
Question, without unhooking the vaccum hose we connected, how can I take it out of 4wd and into 2wd. My neighbor, a lifetime mechanic is positive there is a way to take it out of 4wd, a level, or something to disengage the front wheels.
There is no 4wd shifter like jeeps and other 4x4 vehicles have. Altough, if it passes emmissions, we will buy a new transfer case and install one, right now there is no shifter.
Right now all it has is a button press for 4hi and low.
Old 08-09-2005, 08:37 PM
SBlazerNCS SBlazerNCS is offline
Re: 93 Blazer/Jimmy 4wd problem
If you are in 4 hi right now, press the 4 hi button again.
Old 08-09-2005, 08:59 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
I don't get your question.......
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-09-2005, 09:11 PM
Only thing I figured it could be was he engaged 4wd and can't figure out how to get it back out.
Old 08-09-2005, 09:18 PM
97BlazerDude's Avatar
97BlazerDude 97BlazerDude is offline
Re: Re: 93 Blazer/Jimmy 4wd problem
What is wrong with pushing the button? Isn't there a 2 HI button?
I can wear a blazer. I can drive a blazer.
Old 08-09-2005, 09:25 PM
There is no button for 2 hi. When the thing is in 4wd, either 4 hi or lo, the respective light on the button is lit up either green or amber. If you are in 4 hi now, the bulb below 4 hi will be lit green. All you do to disengage from 4 hi is push the 4 hi button again, the green light will click off.
Old 08-09-2005, 11:49 PM
sorry if i worded the question so you couldnt understand. thanks, ill try pressing the button again.
Old 08-10-2005, 12:23 AM
one quick question...
we have an old 87 chevy s-10 that we just beat the piss out of and drive it through a field and just have fun with...
anyway, my jimmy's master cylinder only half works..it only makes the front brakes work.
is it possible to take the master cylinder of an 87 s-10 and put it on my 93 Jimmy? The look the same size.
