Old 08-09-2005, 04:52 PM
kcc469 kcc469 is offline
Need Help CRX Running too rich
I've a 89 CRX with 95 1.5L engine with MOMO air intake manifold and aftermarket header. I've failed emmissions twice. Things that were replaced or cleaned.: New Oxygen sensor, New PCV Valve, New Spark Plugs, New Oil & Filter, Good after market Air cleaner. Good condition injectors. It's still running very rich. Also when the car warms up you get the check engine light. What am I missing? How can I pass emmission. Is it the MOMO Manifold please help? Thanks in adv.
Old 08-09-2005, 05:45 PM
fierangero's Avatar
fierangero fierangero is offline
Send a message via AIM to fierangero Send a message via MSN to fierangero Send a message via Yahoo to fierangero
Re: Need Help CRX Running too rich
yeah im having same problem, im gonna replace the injectors next, easy to do on a DPFI as there are only 2 and they are in the intake manifold
Rest In Peace, Rich Hall
my baby: 1986 Fiero GT: v6, automatic, 2.8L, 2.02/1.60 heads, Crane Performance Cam, Ported/polished exhaust manifolds, taylor plug wires, low temp thermostat and fan switch. WCF catback exhaust
She's done!
Old 08-09-2005, 08:20 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
what does the cel say?
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 08-09-2005, 09:26 PM
I wish I knew how to read the CEL? That is what i'm trying to do. any suggestions on how to read ?
Old 08-10-2005, 12:06 AM
AF - Advisor
http://honda-tech.com/zerothread?id=468260
Old 08-10-2005, 06:44 AM
I tried this morining in a hurry and twice got quick repeted blinks of 17. It meant that there is something wrong with the speed sensor. I know that I don't have a speedo cable, but that shouldn't be why the car is running very lean. I'll clr the ecu codes and retry this evening and let u know. Meanwhile any other suggestions?
Old 08-10-2005, 08:36 PM
OK checked this eve. Confirmed code 17. Double checked spedo cable missing. There r no other codes that light up. Reset the ecu. Ran the engine for about 3000rpm for 3 min checked ecu no new codes. But still running lean. Would a adjustable fuel pressure be the answer?
Old 08-10-2005, 08:44 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
just unplug an injector... cuts down fuel consumption greatly
Old 08-10-2005, 08:56 PM
Thank I'll try that, Won't it miss?
Old 08-10-2005, 09:20 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
oh dear
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 08-11-2005, 12:16 AM
AF - Advisor
Re: Re: Need Help CRX Running too rich
why try unplugging two while your at it. that'll save even more fuel
Old 08-11-2005, 12:54 AM
jestersrain's Avatar
jestersrain jestersrain is offline
Send a message via AIM to jestersrain
i tryed that one time but the car stoped working for some reason?
1991 HONDA CRX Si dead and gone you will be missed
Old 08-11-2005, 07:39 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
First you're running rich, now you're running lean. If you are going by what an A/F gauge says, just unplug it and throw it away. And why don't you have a speedo cable? weight reduction? LMAO
2008 KIA Spectra5 SX
2010 Honda CR-V EX
