Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 08-09-2005, 04:39 PM
racingrican87 racingrican87 is offline
Exclamation dohc zc help needed
i did a dohc zc swap in my 94 civic lx and it runs but it doesnt move in any gear(1,2,3,4,5,R) it has new clutch,flywheel. everything is hooked up correct so what could it be. if any one has a tip or clue to what it could be just respond plz..
thanks
Old 08-09-2005, 06:33 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: dohc zc help needed
Try bleeding the fluid, and check the fluid as well. You also might have to adjust the clutch pedal a little to compensate for the new clutch.
Old 08-09-2005, 08:39 PM
i already did it. cause u can just shift it it the gears and the higher the gear the higher the mph gauge goes but when i engauge the clutch and hold it it dosent do anything at all. but thanx for the help u have already gaven me and if u have any other tips just let me kno
thanx.
