Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 08-09-2005, 11:25 AM
paxmanhorn paxmanhorn is offline
timing belt concerns
I am preparing to change the timing belt on my 93 Sol. I have called all of my local parts dealers, as well as the Honda dealership. All the parts stores are ranging from $28 - $40, where the Honda dealership is $54. My questions are these: Are all timing belts essentially the same, or would I be better off spending the extra money and getting the one from Honda? Is the one I would get from Honda an aftermarket brand that I could be getting from my local parts store cheaper, or is it a genuine Honda part that cannot be sold anywhere else?
Thanks in advance for any help you can give.
Carl in Texas
Old 08-09-2005, 04:47 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Re: timing belt concerns
I would most definatley go with the Honda one. I believe Gates makes some of our T-belts, but not all of them. You do not want to take any chances when messing with a belt as critical as this one. Plus, you know its gona work. What if you get it all apart, omly to find that the autozone belt isn't the correct one? Piece of mind is priceless in my opinion.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 08-09-2005, 11:28 PM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
Spend the extra $14 and get the one you know will work.
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
Old 08-22-2005, 09:16 AM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
I'd get the Honda belt. I completely concur with Privatebigandrew. Or spend a LOT more and get the Toda belt.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
