Go Back   Automotive Forums Car Chat > Cadillac > Seville
Old 08-09-2005, 11:01 AM
ZZZZDRAWING ZZZZDRAWING is offline
opinion on bad head gasket diagnoses
I have a 88 seville with a 4.5 litre
i think i have a bad head gasket but want to run it be you folks
smell antifreeze after warm up
looks to be motor oil in the radiator fill container
ruff re-start after warm up
fluid is always low but i can find no leaks
un-stable temp. readings
if this does'nt sound like head gasket to someone let me know before i get into this high labor job.
any help is highly apprecaited
thank you
Old 08-11-2005, 10:27 PM
ctesla's Avatar
ctesla ctesla is offline
'88 with a 4.5 and how many (xxx,xxx) miles?
sounds like, but I'd pull plugs at the minimum and check compression.
if you've got oil in antifreeze and/or vice-versa, definitely sounds internal.
may only be one side, but if your doing a teardown, hardly anymore labor to do the other side while it is sitting there, rather than in three to six months.
