Old 08-09-2005, 08:38 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Trans fluid gasket filter pan
I was wondering if you guys had some input on what I am about to do? I am going to drop the pan, drain the fluid, change the filter, new gasket, refil with tranny fluid. Should I refill with the same regular tranny fluid or can I refill with synthetic and have both synthetic and non synthetic in the tranny? I know it is ok to do wil oil just wanted to make sure it was ok with tranny fluid. If it is ok what kind of results should I expect from someone who has done it or who has had a flush and refilled with synthetic? Thanks guys
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 08-09-2005, 08:41 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Trans fluid gasket filter pan
Before you do that I would have the transmission fluid completely replaced with one of those machines that hook up to the transmission cooler lines.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-09-2005, 08:54 AM
Re: Re: Trans fluid gasket filter pan
I did the flush last year. The place that did it said my tranny fluid looked good then and I had owned the truck for 35k at that point and had not had it done and I have no clue when the woman before I had it did it. So I had it flushed last year and everything was ok. think I still need to get it flushed?
K&N Air Filter
Old 08-09-2005, 09:03 AM
BlazerLT's Avatar
AF -Advisor
No, just replace the filter and use normal ATF to top it up.
No sense using only a little bit of synthetic.
Old 08-09-2005, 09:18 AM
I hear yea. About how much transmission fluid is lost when you drop the pan and swap out the filter?
K&N Air Filter
Old 08-09-2005, 09:23 AM
DINO55's Avatar
DINO55 DINO55 is offline
About 4 Quarts or so......
Get ready to take a HOT bath in transmission fluid my friend...
Been there, done that................................
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 08-09-2005, 09:45 AM
BlazerLT's Avatar
AF -Advisor
I don't think it will be a full 5 qts with just the pan drop. I may be wrong.
loosen the pan bolts and loosen one corner more than the other four.
That way you can place a pan under that corner and collect what you drain.
Old 08-09-2005, 10:13 AM
I hear yea on the tranny bath! I learned that the hard way on a grand prix I used to own, but since then I do it the way BlazerLT suggested, just loosen it enough to let it pour out one corner. I can't remember how mych fluid a friends blazer took when we did it so that is why I asked about how much was lost.
K&N Air Filter
Old 08-09-2005, 10:24 AM
DINO55's Avatar
Make sure you clean the pan of all old gasket meterial , carefully install a new O ring and filter, and don't overtighten the bolts, yada yada yada. Your trans will thank you later.
Old 08-09-2005, 10:37 AM
I know a lot of people who over tighten things and have no idea that is where some of there problems caome from, fools
K&N Air Filter
Old 08-09-2005, 12:20 PM
lostmartian63 lostmartian63 is offline
what should the ft/lbs of torque be on the tranny pan?
Old 08-09-2005, 01:31 PM
blazee's Avatar
blazee blazee is offline
Problem?
8 - 10
Old 08-09-2005, 02:43 PM
Originally Posted by blazee
8 - 10
Are you for real or did you pull that out of your ass?
I am sure you are right I just wasn't that question or answer to pop up! haha
K&N Air Filter
Old 08-09-2005, 03:16 PM
97BlazerDude's Avatar
97BlazerDude 97BlazerDude is offline
Re: Re: Re: Trans fluid gasket filter pan
ATSG manual says 9 ft-lbs torque to be exact.
I replaced my valve body on my 97 (4L60-E transmission) and refilled 4 qts. I had 5 qts on hand, just in case.
Tip = when retorquing the pan bolts, be very careful on the front middle bolts. It is tough to get those bolts threaded in properly because there is not much clearance between the pan and the cross member. Be sure to thread the bolt in to the case carefully to avoid cross threading the case. If you feel too much resistance, stop and back the bolt out and try again.
I can wear a blazer. I can drive a blazer.
Old 08-09-2005, 03:58 PM
blazee's Avatar
Problem?
I got it from the Haynes manual. The haynes manual isn't always right, but I knew that the spec was pretty close to what I've seen before.
