Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 08-09-2005, 01:47 AM
Ridleyj329 Ridleyj329 is offline
horse power?
what the factory horse power for a 92 SC2 DOHC. and what are all the options for increasing it?
Old 08-09-2005, 01:51 AM
Mines69Olds's Avatar
Mines69Olds Mines69Olds is offline
Send a message via AIM to Mines69Olds
Re: horse power?
Well the hp is probably around 124. The performance options are totally uo to what you want to do and how much you want to spend.
Old 08-09-2005, 01:54 AM
Re: horse power?
so factory hp is 124? is that good or bad? what are any options, suggestions, or idea?
Old 08-09-2005, 09:50 AM
Re: Re: horse power?
I think a nice intake and exhaust are what you should be looking at first. Just start searching around and I'm sure you'll find a Saturn performance website with those parts.
Old 08-09-2005, 02:31 PM
Re: horse power?
what all would be included in the exhaust? the whole system, headers down to the muffler? also how relyable are the performance parts found on ebay? the cheaper the worse quality or not?
Old 09-03-2005, 05:34 AM
rrclyoung's Avatar
rrclyoung rrclyoung is offline
Re: horse power?
I don't think Saturn and Horsepower should be used in the same sentence....
Old 09-03-2005, 10:45 AM
Go for the full exhaust system. But don't forget to buy something for the intake as well. As of the ebay parts I'm not to sure about that.
I bought an SL1 1.9 litre SOHC 5 speed as an economy car. This car is funny it burns 1 quart of oil for every tank of gas. I was at college the other day with my brother and we were on our way out. We were sitting at a 2 way stop and I waited so it was my turn. I start pulling out and some stupid girl thinks it's her turn and she is about to pull out right into me. I very calmly just pushed my foot to the floor and what do I hear? (That is right this little thing does have something) It burned tire for about 10 feet. We were sitting there laughing our asses off. I never though it possible for a beat up 1995 with a 1.9 to do that but crazier things have happened.
Old 09-06-2005, 12:56 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
First, you have a 92 model car so you have the free flowing header i assume (i have one too on my 97 sl2) so i would stick with that if you wanna save money. a cold air intake is a must too. i would go with the AEM version and get their bypass valve (shuts off the relocated air filter if it is immersed in water so it doesn't go in the engine) but there isn't anything wrong with getting one from ebay. You can also get the throttle body at www.spswebpage.com or you can widen it more yourself with power tools or something (a grazer works best). I don't know if there are any exhaust kits for the 92 (probably are) or you can custom make one. either way, it's worth it. A muffler helps too but the source varies. I recently bought an APC titanium muffler a few days ago for $50 (retail is $300) but haven't received it yet so i will get back on that and see if i'm getting screwed (pretty sure i won't). Lastly, which i'm not sure about is the $400 intake manifold from www.spswebpage.com. I plan on getting this hopefully in the next few months but don't know how effective it will be on the saturn nor if it is available for the 92 (if anyone knows you should post). To sum up, you wanna increase the airflow from the header and as it exits the car; the easiest way to make horsepower for good money. ebay is an okay source, just be careful and smart on what you choose. there are a lot of options so you should look at many.
Old 09-07-2005, 12:28 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Re: Re: horse power?
i would advise against the SPS intake manifold expect for high RPM race and F/I engines. the increased runner diameter allows for more air at the cost of velcotiy. it increases the peak HP RPM(and the stock peak HP RPM is already just shy of the redline) at the cost of decreaseing lower RPM power.
SPS dyno readouts - http://www.spswebpage.com/tech/index...ID=a5220vs5232
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Old 09-07-2005, 05:58 PM
Re: Re: Re: Re: horse power?
Thank you for saving me, er, us (saturn owners) a lot of money sierra.
Old 09-07-2005, 10:49 PM
Re: horse power?
its just my 2 cents
remember, real engine builder don't just buy any part that seems like a good idea. or parts one by one. they research, design, set a goal output/result, and buy matching parts. just bolting on parts can infact cause a loss of power(in my school's power and performance class that was the frist dyno test we did, a common aftermarket add-on that infact caused a loss of power). a good engine builder can build a better engine with less resources then a uneduicated engine builder.
Old 10-13-2005, 12:31 AM
billyturbonitrosl2 billyturbonitrosl2 is offline
Re: horse power?
a few mods you can do remove egr and block with a metal plate i recently raised the compression ratio in my 93 sl2 dohc by using a sohc block and internals.i got rid of the rev limiter by putting a auto pcm on manual trans (pain in the ass)
Old 10-13-2005, 10:28 PM
frist, removing the EGR can cause excessive combustion chamber temps, and even possible engine damage. second, i'm sorry to inform you but to the best of my knowage DOHC heads and pisions has higher compression then a DOHC head and SOHC pistons(that what the turbo guys say, they like low compression)
Old 10-14-2005, 04:26 PM
my bad the DOHC eng comp. ratio is 9.5:1 the SOHC is 9.3:1 the SOHC pistons have a bigger dish in the middle and the DOHC also have valve reliefs in them. I have a 75shot nitrous express kit on the the SOHC block with the DOHC fully ported/polished head with no EGR and no problems yet.The turbos going on in the next week or two.
Old 10-14-2005, 10:23 PM
Re: horse power?
whats your plan for the fuel system?
