Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 08-09-2005, 02:11 AM
bluevp00's Avatar
bluevp00 bluevp00 is offline
Unhappy 00 civic burns oil
I have a 00 civic w/ a D16Y7 engine (1.6L). I lose about 1 quart every 2000 miles, and I know it doesnt leak. the car has about 100,000 miles & I bought it with 82,000 miles. ever since I got my car I changed the oil with 5W30 synthetic, could this be why I'm burning so much? or could it be the piston rings or the valves? or is 1 quart every 2000 miles acceptable for over 100K miles? The inside of the talipipe is black & dirty, but it doesnt smoke (at least not any visible smoke). can anyone give me advice?
Old 08-09-2005, 09:05 AM
cas4067 cas4067 is offline
Re: 00 civic burns oil
my 96 civic ex 5spd (96,000 miles) does the same thing. But I noticed if I don't rev it past 4,200 rpms (so the vtec dosen't kick in) it burns no oil. Also I have brought mine to a shop and they said the only thing they could do is motor. I know I didin't answer your problem but if you find out a solution let me know...
check it out let me know what you think
my ride
Old 08-09-2005, 11:47 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
First you need to figure out when the car burns oil...when there is visible smoke (if there is any)
1. IF it burns oil on acceleration, you have excessive blow-by gas passing by the piston rings....bad rings
2. IF the car burns oil on deceleration i.e. when there is a lot of vaccuum, because oil is being pulled through the gap between the valve stem and the valve guide...then the valve guides are worn
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 08-09-2005, 01:19 PM
exman98 exman98 is offline
Re: Re: 00 civic burns oil
d16y7 is a non vtec motor, d16y8 is. i believe it kicks in around 5,500 rpms, unless something is changed.
so you are asking me what should you make? Ummmmm.... well i vote meth lab.....helps out the community and gives people like you a job
I love out driving people.
"what's all those cylinders for anyway"
Old 08-10-2005, 01:09 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
a compression test will be a good confirmation.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
