Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 08-09-2005, 12:43 AM
chino26 chino26 is offline
2000 sunfire 2.2l Not starting
Two months ago my sunfire would not start after work.Spark OK Fuel pump was comming on.It would roll over but nothing.
Towed it to a friends about 10 minutes away to change fuel filter when we got in the yard it started.
ther has been no problem since and today it did it again
is there some way of resetting the computer or security mode???
Old 08-09-2005, 05:52 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 2000 sunfire 2.2l Not starting
If the security light is on, turn the ignition key to the on position and leave it on for 10 minutes, turn off for 30 seconds and turn on for another 10 minutes. Do this three times after the third time try to start the car. Should start. If you have another OEM key try that, it will work sometimes.
Old 08-09-2005, 09:08 AM
Thanks alot ill try that
Old 08-09-2005, 11:40 PM
no luck
the security light comes on when u turn the key on but goes off
the battery and oil light stays on
guess ill tow it around again
maybe the fuel pump presure is not enough
Old 08-12-2005, 12:12 AM
93cavy 93cavy is offline
Send a message via MSN to 93cavy
i believe you are having the same problem as me, what i do to get it to start is to wiggle the key while trying to turn it over, if that does not work i put it to the on position and shift it into gears and then back to park then keep on turning the key and eventually it will turn, but i have a question, when you try to start it does the engine do anything at all?
Old 11-27-2005, 11:43 AM
brettboy brettboy is offline
my car did same thing it acts like fuel pump but it is not its actually the sock on the fuel pump is collapsing and needs to be replaced
