Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 08-08-2005, 11:50 PM
szinter szinter is offline
99 explorer ABS light, I have codes
I have a 1999 ford explorer. When I had the codes pulled for my abs light, there was four different codes. The two front sensors, the back sensor, and the G-switch. The codes are as follows C1150, C1145, C1230, C1102. What could this be?
Old 08-09-2005, 01:20 AM
exploded99 exploded99 is offline
Re: 99 explorer ABS light, I have codes
First time I've heard of someone getting a g switch code. Its a guess, but I don't think all three abs sensors had real problems at the same time.
So I suspect the g switch set the code. Perhaps the g switch told the system you hit something but the abs sensors kept moving, so the system got flumoxed up and set the codes.
You could go out and hit something hard and see if the g switch works, so the airbags go off, or you could get a second opinion.
Maybe way2old has some reference materials to help you with, but I'd guess if the g switch is setting a code it will need to be replaced.
Old 08-09-2005, 02:13 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
See if this helps. Try to resolve the code for the switch first. The switch is located on the frame on the drivers side. It is located behind the fuel filter. There are 2 nuts on the outside of the frame that hold it on.
F8 CHECK G-SWITCH, DEFAULT G-SWITCH POSITION
Place the G-switch on a level surface.
NOTE: The G-switch must be in the same position it would be in the vehicle.
Measure the resistance between G-switch Pin 1, and Pin 3; and between G-switch Pin 1, and Pin 2 (component side).
(pin 2 is the center, pin 1 is the bottom of the switch as it sits on vehicle, pin 3 is the top of the switch as it sits on vehicle.)
Are the resistances less than 5 ohms?
Yes
GO to F9.
No
INSTALL a new G-switch; REFER to Switch—G. CLEAR the DTCs. REPEAT the self-test.
F9 CHECK G-SWITCH, FRONT OF G-SWITCH RAISED 38.0 MM (1.5 IN)
NOTE: The arrow on the G-switch points toward the front.
Raise the front of the G-switch 38.0mm (1.5 in).
Measure the resistance between G-switch Pin 1, and Pin 3 (component side).
Is the resistance greater than 10,000 ohms?
Yes
GO to F10.
No
F10 CHECK G-SWITCH, REAR OF G-SWITCH RAISED 25.4 MM (1 IN)
Raise the rear of the G-switch 25.4mm (1in).
Measure the resistance between G-switch Pin 2, and Pin 1 (component side).
Yes
INSTALL a new anti-lock brake control module; REFER to Anti-Lock Brake System (ABS) Module. REPEAT the self-test.
No
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 08-09-2005, 05:08 PM
wow, if the g switch tests ok you gotta go for a new abs module. That will whack your wallet.
Old 08-09-2005, 07:08 PM
way2old's Avatar
TOKEN HILLBILLY
That is just the test for the switch exploded99. there is 20 pages of wiring tests. That easiest the easiest to post.
Old 08-10-2005, 02:11 AM
Granted I am assuming the wires are good. I guess in my experience you get a code that refers to the circuit itself if its wires or a complete failure of the sensor - ie - here we'd get a "g switch circuit bad" code.
I am going to have to get me one of those shop manuals. The info in there is amazing.
Got any awd transfer cases around your shop I can have for a bottle of scotch? My 99 is having its own issues. If you are close to Denver I can drive over to pick it up.
Old 08-10-2005, 10:11 AM
way2old's Avatar
TOKEN HILLBILLY
I don't think Ky is very close to Denver. Go to www.flatratetech.com and for a small donation you may be able to purchase the DVD for your vehicle.
Old 08-10-2005, 04:31 PM
Re: Re: 99 explorer ABS light, I have codes
Dang. They only go back to 2000. Oh well, thanks anyway.
Old 08-11-2005, 08:00 PM
way2old's Avatar
TOKEN HILLBILLY
Let me check my resources. If I have a duplicate 99 DVD, I may be persuaded to relinquish it.
Old 08-11-2005, 10:37 PM
[quote=way2old]See if this helps. Try to resolve the code for the switch first. The switch is located on the frame on the drivers side. It is located behind the fuel filter. There are 2 nuts on the outside of the frame that hold it on.
Yes
GO to F9.
No
Yes
GO to F10.
No
Yes
No
Would you know if a used control module would work or if I would need to have if configured to the vehical?
Old 08-12-2005, 07:34 PM
way2old's Avatar
TOKEN HILLBILLY
As long as it is from the same model, year and trans, all should be OK. We swap ABS controllers from wrecks constantly.
Old 08-13-2005, 12:45 AM
As Bob Barker says,
"Lets make a deal!!
