Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-08-2005, 10:30 PM
DigitalPhantom DigitalPhantom is offline
Shifting Problems...
Ok, I have a 97 Integra GSR and Im having problems shifting through the gears. First and second are usually fine, however shifting into third is a pain in the a$$. I clutch, and go to shift and it feels like something is preventing my from shifting...the RPMs drop like 3k from what I was at, then it goes it usually without a problem. And the same goes for 4th and 5th. Today, on my way back from work, I stopped a light, and went to put it into first, and it would not go into first at all. I tried pushing really friggin hard too, but didnt wanna do any damage. So I looked like a retard in the middle of an intersection with my hazards on, because I couldnt put it into gear. I turned the car off for 10 seconds, started it again, and it went right into 1st no problem. Also today in my driveway I put the car in reverse, with the clutch in, and it just stalled. THe clutch was all the way in. I tried it again, and same thing. Its royally pissing me off. Maybe is the syncros. Any help would be friggin spectactular. Dunno if this happened to any of you out there.
Old 08-08-2005, 11:09 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Shifting Problems...
My friend is working on a car right now that had that problem. We bled the fluid today and it shifts fine now. So check the fluid and try bleeding her.
Old 08-08-2005, 11:55 PM
Re: Re: Shifting Problems...
Alright sounds good man, thanks.
