Go Back   Automotive Forums Car Chat > Dodge > Dakota
View Poll Results: soft brakes 89 dodge dakota
no leaks shown 0 0%
fluid level very los 0 0%
Voters: 0. You may not vote on this poll
Old 08-08-2005, 09:41 PM
aldridl aldridl is offline
soft brakes
I just had the rear end replaced on this Dodge, drove it for 1 month and the brakes are getting soft, checked fluid level it was very low,, did not have this problem until rear end changed...Do not see any leaks from cylinder or on floor mats, do not see any leaks near rear tires
Old 08-09-2005, 12:37 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: soft brakes
it's possible that when you had the rear end replaced the wheel cylinders or one of the wheel cylinders was bad. Also, check to be sure there's no fluid around the brake line on the backing plate of the brake drum.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 08-09-2005, 11:26 AM
Wa jang chang Wa jang chang is offline
Re: soft brakes
I suggest you fill up the brake fluid reservoir and drive for few days to see if the fluid level changes. Did you see any BRAKE/ABS lights coming on on the instrument panel? I just replaced 8 ft of brake hydraulic line on my 97 dakota due to corrosion damage. See my posting under the thread heading "brake trouble", if you ever need to replace the line.
wajangchang
