loss of boost pressure....?
ok so driving i thought i might have heard sumtin but it was too fast and not sure what or where it came from.... but my car has what seems ta be loss of power in the turbo.. the boost gague wont go past three.....not ta mention to actualy get the car to move i feel like its ready to stall without reving kinda high....any input is good thnks
Re: loss of boost pressure....?
sounds like one of your intercooler pipes has come loose, check the connections. The easiest way to find something like that is to pressure test. If you have access to an air compressor/air tank, then you can build your own pressure tester in which if you search the drop box on stealth316.com, you can find it. Other wise you can buy one from 3sxperformance or look up robbeck on 3si.org
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
Yeah, check your intercooler pipes and your y-pipe going into your throttle body.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
I agree with both - i already had that problem ... when i was racing a audi S6 bi-turbo i was pushin her hard to win an sounded like a blew a vacume line or something it took me a while to figure out what acually happend - untill i looked down in the front by my radiator on the drivers side - I blew the hose an clamp off the cooler bung.... i was like holy smokes - cause the car ran like hell - like someone dumped sealer in my valves - then reconnected it an ran like new again....
93' Stealth R/T Twin Turbo Intercooled - 24v DOHC 3.0 v6 engine - AWD AWS - 320 hp 317 lb ft. torque when I bought her unmolested hoping to be in the 600-700 hp when finished with ... ![]() ~FASTER THAN A SPEEDING TICKET~
my boost would not spool at all when it happend to me - so u might have a crack or a minor leak...
Re: Re: loss of boost pressure....?
well my boss ran it hard today and seemed like it ran better.... the car didint idle shity or anyworse then it did lol... he said it could jsut be shit in the engine making it not run right like carbons and stuff.... yes? no?
you can also try throwing some dry gas in the tank b4 u get to the point of checking inside the engine - u might have some moisture or water in your gas or tank that doesnt want to leave ...
Matt |
Matt |
