Air Conditioner
Can anyone help me?
I have a 2000 Grand Prix. The problem started when I noticed wet carpet on the passenger side floor. Since then, the a/c stopped blowing, however I can feel cold air at the vents. Can anyone tell me what the problem may be with the a/c?? |
Re: Air Conditioner
The water is probably due to a blocked vent drain. You can clean it out by reaching up along the firewall and finding the drain. Run a heavy wire, coat hanger will do up the drain and you should open it up. The other problem may be a blocked vent or a bad fan. If the fan is bad, due to water it will not push air hard enough to blow. You can also clean this out by removing the passenger seat and getting way up under the dash and remove the fan. Reach up into the vent area and clean everything out. This will also allow you to clean the fan blade that may be blocked with foreign matter. This should help your problem.
