Old 08-08-2005, 04:48 PM
Ann Swisher Ann Swisher is offline
Angry jeep problems again
1995 jeep cherokee sport just died now won't start, gauges work, has 6 month old cam positioning sensor which seems ok. Not loose anyway. I have no spark when I pulled a coil wire and had engine cranked. What next.
Old 08-08-2005, 06:54 PM
Dale Aeppli Dale Aeppli is offline
Re: jeep problems again
Hi Does the check engine light come on when you turn key on, also can you hear the fuel pump run it should run for 2-3 secs. when you turn key on. Did you have the sensor on the bellhousing changed or the one inside the distributor changed. Dale [email protected]
Old 08-08-2005, 11:48 PM
Re: Re: jeep problems again
Yes, check engine light comes on. We did not hear the fuel pump at all. Is the pump in the tank? We changed the sensor on the bellhousing. Thanks
