Old 08-08-2005, 03:07 PM
mtpina mtpina is offline
Send a message via Yahoo to mtpina
Unhappy HELP !! HELP !!! AC/ blower control module
Need your help to find this part because down here southwest texas the heat is like hell, and wit no A/C worst.
need help to see if anyone has a module like these, it goes under the glove compartment at the firewall, it supposed to control the a/c - heater fan speed part # 52479971, i can send some pics if you nees
Thanks in advance.
Mtpina
'03 Mazda6s 3.0
'00 Grand Prix GT
Del Rio, Tx
Old 08-09-2005, 12:01 AM
dmasjz45 dmasjz45 is offline
you want to look for the blower motor resistor, its guna be a 20 dollar part and its located on the passenger side under the dash on the firewall..i believe 3 screws are holding it in. can be a pain to get to, drop the blower motor out of the way. from what i remember at least, i've never done it first hand
http://www.partsamerica.com/ProductD...pe=861&ptset=A
Old 08-09-2005, 08:36 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: HELP !! HELP !!! AC/ blower control module
He's not looking for a blower motor resistor. Check out the GM part number. Its a blower motor control module and it runs $150.00 retail list at the dealer.
If you're going to dish out advice make sure you know what you're talking about otherwise all you'll do is confuse people.
Thrasher CAI, DHP v1.0 PCM,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 TB,
TB spacer, MSD 8.5mm wires, Autolite 104s,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
Timeslip 08/12/06
AF Community Guidelines
Old 08-09-2005, 10:16 AM
neverind your right im wrong, my buddy had a sunfire and this is how we fixed his problem, had the same problem and it controls fan speeds..im not big on hvac as i said first hand, but after some research im starting to believe these are only in gtps with dual climate? cant be right all the time at 3am, i usually dont put when im not sure but i guess im a moron
www.gmpartsdirect.com
