Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 08-08-2005, 03:50 PM
scarecrow0529 scarecrow0529 is offline
c.a.i.
i was wondering if anyone knows the diameter of the bottom pipe of a c.a.i. intake. i am thinking of making my own using exhaust pieces. or i just might do the ram air by cutting into my hood and putting a scoop on it. i would like some opinions on which would be better. also i dont have foglamp holes its a 92 sc2 so for cold air where would i go with the filter.
Old 08-08-2005, 11:18 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: c.a.i.
i perfer ram air, a little less chance of sucking water. also most CAI are 3" i beleave(but thats not the same size as the throttle body)
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Old 08-09-2005, 01:55 PM
hey sierra you say you prefer ram air did you cut out a hole for a scoop or do you just have the warm air intake. i know that whole argument about the water being sucked in. on the fence about that one. thanx
Old 08-10-2005, 12:13 AM
Re: c.a.i.
i have just a short ram/WAI intake, i hope some day to make my own fiberglass hood with a scoop(since someone kicked in my hood anyway). i also briefly played around with the idea of a ram air headlight set-up, but never finished it.
keep in mind the idea behind both CAIs and ramair is to not suck in the hot underhood air and reduce airflow restriction. the actual ram air "supercharging" effect won't increase your manifold pressure above atmoshperic pressure until somewhere just shy of 1/2 the speed of sound.
Old 08-10-2005, 02:41 PM
i remember reading about a 95 eclipse non turbo c.a.i. off of ebay would work i just have to rig it. is this true cause those things are cheap. you know spending over 200 bucks for something that may give you a little horsepower just doesnt work for me.
Old 08-12-2005, 12:09 AM
Re: c.a.i.
it will work if you don't have a automatic transmission.
Old 08-12-2005, 02:22 PM
its a manual. i think i will just used some exhaust pieces to get the filter out of the engine compartment.
