Old 08-08-2005, 02:37 PM
amiee1981 amiee1981 is offline
89 taurus door lock code
I just bought a 1989 ford taurus sho. The owner did not give me the code to the door lock buttons on the driver door. Does antone know where i can get this at?
Old 08-08-2005, 09:55 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 89 taurus door lock code
Did you get the owner's manual and booklets with the car? If so, there may be some stickers with 5 digits on them in the owner's manual packet, those 5 digits are you keypad code. Also, the code should be on a sticker affixed to the keyless entry module. I'm not sure where it's located on the '89, but on my '93 SHO the module was mounted in the trunk near the driver's side seat back. It was a black box with a white sticker, the white sticker had my 5 digit code on it. The code was also on a sticker affixed to the underside of the trunk lid. If you find a white sticker with a 5 digit code on it, that is probably your default code. You can program in a unique code once you have your default code, but the default code will always work.
Good luck,
-Rod
Used to have a red '93 SHO
Currently have a green '98 SHO
Old 08-09-2005, 03:12 PM
Thumbs up Re: 89 taurus door lock code
Thanks For The Help....
