Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 08-08-2005, 12:05 PM
thelosman thelosman is offline
Angry screwed up tranny??????????????????
I was traveling down the interstate late one nite, a little boared, and
decided to see how fast my 93 lude would really go. since there was noone else in sight I down shifted into fourth and gunned it! after I pulled up to about 100 or so I shifted to fifth and proceeded to about 130 or better where i held it for about a minute. when I exited the interstate and came to the first light, my car started to act a little wierd
comming off of first gear. by the time i made it home i could only get the car into fourth gear where it is stuck now. and if that isnt weird enough... fourth gear really isn't fourth- neutral is fourth. If i try to force the stick into any other gear, i hear terrible grinding sounds and sometimes smoke from under the hood. I can drive the car somewhat normally in fourth gear only. any comments questions or suggestions......
i will listen.
Old 08-08-2005, 02:11 PM
honda_racing101's Avatar
honda_racing101 honda_racing101 is offline
Send a message via AIM to honda_racing101 Send a message via MSN to honda_racing101 Send a message via Yahoo to honda_racing101
Re: screwed up tranny??????????????????
Hmmm shift linkage somewhere maybe?
dSoc member #67
1995 Honda del Sol EG2 VTEC Milano Red. RIP :crook:
1994 Honda del Sol EG1 S-full VTEC conversion.
Buy my Del Sol parts!!
Old 08-08-2005, 04:49 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Definatley start at the shift linkage. May have bent something, or possible the linkage is kinkied and in a bind. (if it uses cables and not the rods)
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
