Old 08-08-2005, 09:45 AM
strikerty strikerty is offline
Brake bleed sequence
I am in the process of replacing all the brake lines on my 93 lesabre. I was wondering if anyone knew the proper sequence for bleeding the brakes , i know you have to start with a certian tire but i dont know what it is lol
Any help would be greatly appreciated.
Old 08-08-2005, 09:53 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Brake bleed sequence
Right rear
Left rear
Right front
Left front
Old 08-08-2005, 11:53 AM
thanks i appreciate it it has been crazy the more lines i tried to take off to replace the more lines broke lol
Old 08-08-2005, 05:28 PM
kok328 kok328 is offline
Effectively, you start with the connection farthest from the master cylinder. You'll want to hit all connections a day or two ahead of time with a penetrating oil.
Old 08-08-2005, 05:29 PM
Effectively, you start with the connection farthest from the master cylinder and work your way to the closest connection last. You'll want to hit all connections a day or two ahead of time with a penetrating oil.
Old 08-10-2005, 08:43 AM
yeah heh by the time i got done i ended up replacing every single brakeline in the car including one of the flex hoses in the back , and both wheel cylinders as the bleeders broke off both of em . After alot of money spent and more than a few smashed knuckles im still convinced that once i finish the job completely i will still have spent way less than it would have cost me to have it done at a garage considering that they would have ended up doing as much as i had to do and it would have taken them twice to three times as long as originally estimated
