Old 08-08-2005, 08:31 AM
NBery NBery is offline
1997 Buick Lesabre Shuts off when running
Hello Everyone,
I've been having a re-occuring problem with my 1997 Custom Buick Lesabre that My mechanic cannot figure out.
I will be driving at any speed during any type of weather conditions and all of a sudden my vehicle will shut off. When I pull off to the side of the road it will generally fire right back up but on occasion it will take about 5 minutes and then start right up. Unfortunately my mechanic can never get the vehicle to stall when it is hooked up to his computer so it never gives him a problem code. I did recently have a M.A.P Sensor replaced but that was obiously not the problem. Can Anyone help me?
I am not a mechanic and have limited knowledge when it comes to vehicle repair. It has been suggested to me that it is the Crank Sensor but I would like a little affirmation before just pulling out and replacing parts. Thank you for your help.
Sincerely,
Nick
Old 08-08-2005, 12:01 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: 1997 Buick Lesabre Shuts off when running
Originally Posted by NBery
Hello Everyone,
Sincerely,
Nick
Nick
I had my 97 stall like this. It may be a ground problem. Does your dome light dim when you hit the power locks? Does the starter take a bit to get up speed when you turn the key? Mine died when I held the window switch too long after the window was up. There is a ground stud on the right side on the fender well by the battery. Take the nut off and clean all of the terms.
Regards
Dan
Old 08-08-2005, 12:59 PM
i haven't noticed any dimming of the dome light and my starter doesn't seem to hesitate but i will check out the ground as you suggested. thank you
Old 08-09-2005, 07:26 AM
rustbucket rustbucket is offline
Search this forum for crank or stalling, threres plenty of incidents
Old 08-10-2005, 11:41 AM
Re: Re: 1997 Buick Lesabre Shuts off when running
Thanks rust bucket.... i did do a search and the timrice superblog Sounds like a complete rehash of what i'm going through. i appreciate it.
Old 08-17-2005, 11:59 AM
Re: Re: Re: 1997 Buick Lesabre Shuts off when running
NBery
How are you doing with your 97? Find anything?
Dan
Old 08-21-2005, 12:44 AM
s426 s426 is offline
hi
it happened to me. in my case i thought was alt,fuel line clouged,fuel pumb faliuer,bcm.
but it was the postive cable in bat terminal was all build up on it,
you need to check that , remove the pos<+> cable off the bat, then take the red terminal rubber sleve off. clean all copper flat ends.
Old 12-19-2005, 02:09 PM
Re: Re: Re: Re: 1997 Buick Lesabre Shuts off when running
Originally Posted by LeSabre97mint
NBery
Dan
It ended up being the crank sensor and has been running fine since the middle of August. Thanks for your interest
Old 12-20-2005, 11:06 AM
Re: Re: Re: Re: Re: 1997 Buick Lesabre Shuts off when running
Good to hear that you got it fixed.
Dan
