87 S10 Blazer Wont Go in Gear
I've searched the threads but haven't found an answer to this one....
'87 S10 Blazer 2.8L 4WD - Will not go into gear when it's running. I've replaced: Pilot Bearing Clutch Throw Out Bearing Slave Cylinder Master Cylinder Hydraulic hose between Master and Slave I've bled it till I'm blue in the face and it still wont go into gear when its running. Anybody know what I should try next? Chiltons manual has nothing about troubleshooting and I'm stuck. Thanks. |
try this turn the truck off put the trans in first then push in the clutch and try to start if the truck jumps foward you still have air in the lines if not and it starts fine see what happens when you let out the clutch
also some clutches will fit and engine but wont work too thick thin what ever the case double check to make sure you have the right kit |
Thanks, I'll give it a whirl.
Re: 87 S10 Blazer Wont Go in Gear
http://p207.ezboard.com/bs10extremists |
