Go Back   Automotive Forums Car Chat > Chevrolet > Corvette
Corvette
Old 08-07-2005, 09:28 PM
Doc Blazer Doc Blazer is offline
79 vette cruise control
Im going to work on my 79 vette cruise control. I got the car a year ago and it never has worked since I got it. Is there any componet failure in the system that is common for this vintage of vette? And does anyone have any troubleshooting tips on this cruise control system?
Old 08-08-2005, 09:15 AM
Ecordeddie's Avatar
Ecordeddie Ecordeddie is offline
I've got a '79 as well. The good thing is that there isn't much to the cruise system... Basically it's just the wiring and the cruise control module. I've met a few '79 owners at shows with cruise control. When it's gone band its been the module under the hood on the passenger side. I've got a shop manual. I'll look up the common problems and let you know if you want.
Old 08-08-2005, 09:43 AM
Re: 79 vette cruise control
that would be great meanwhile I will look for that module. When I try to engage the cruise I see the tach jump momentarily when I push the button on the turn signal
Old 08-08-2005, 03:54 PM
Problem solved. This afternoon I changed the transducer, thats the part under the hood left side fender next to washer tank. It has connections for 2 speed cables , 3 vac lines and 1 elec connector. System worked fine on test drive. Thanks for offering some help.
Old 08-09-2005, 05:07 PM
Ecordeddie's Avatar
Great.... I'll keep that in mind if mine ever goes out...
