Old 08-07-2005, 08:07 PM
jsousa jsousa is offline
random stalling
hello. recently, my escort has been randomely stalling. it will just die out of knowhere, i usually have to turn off the key all the way, then back on, and it will start. my dad is guessing it is the engine computer actuator. help!
Old 08-07-2005, 09:04 PM
KimMG KimMG is offline
AF - Advisor
Re: random stalling
When its running are you getting a check engine light?
Old 08-07-2005, 09:31 PM
nope, it just randomly stalls.
Old 08-08-2005, 07:26 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Maybe the ignition switch? Next time it stalls quickly wiggle the key and see if it kicks back on. Since you said you have to turn the key all the way off and then back on this is what I would suspect.
Nevada Tumbleweed
Old 08-08-2005, 07:34 AM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: random stalling
How about basic infomation like when was it tuned up last? (could be why its stalling)
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 08-08-2005, 11:06 AM
i highly doubt a "tune up" would cause an engine to randomely stall.
Old 08-08-2005, 11:39 AM
Davescort97 Davescort97 is offline
Escort guy
Re: random stalling
How does it idle? Does it bog down when you turn on the AC, heater fan or lights? Does it idle rough? If it does it probably has a dirty idle air control. It is right on top of the engine next to the throttle body. Sometimes these get clogged up with carbon. Use some carb cleaner and lubricate it and put it back in. If you aren't having any problems with a rough or low idle I think Tumbleweed has got it pegged as a faulty ignition swiltch.
Old 08-08-2005, 11:47 AM
there is no rough idling or anything of that nature. when im driving, it just...dies randomly sometimes. radio, air condition, lights, all still work.
is a faulty ignition switch the same as the engine computer actuator?
my dad is an engineer at ford, he told me that it might be because the engine computer actuator is going bad (the connection inside isnt good) and it will loose connection while im driving randomely, causing the engine computer to loose power, causing it to shut off the engine. when i turn the key back then back on, it starts because the connection in the actuator gets turned off, then on again, usually getting a good connection for a while, until vibration or somethin.
how does that theory sound?
Old 08-08-2005, 08:51 PM
Escort_Service Escort_Service is offline
Re: random stalling
If your dad is an engineer at Ford why are you aksing people here?
5.0 Mustang where would you be if I took 4 of your cylinders? In the scrap yard you ugly piece of #$?@
Old 08-08-2005, 10:11 PM
because
1. he isnt sure
2. its always good for a second opinion
Old 08-09-2005, 11:28 AM
bump.
