Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 08-07-2005, 05:11 PM
Sar Sar is offline
91 Dakota no spark
I went out to start my 91 Dakota (V8, 5.2L) today but there's no spark and it won't start. It ran fine yesterday evening. The TBI is working and the engine is cranking but there is no HT output from the ignition coil. The coil has continuity, but I don't have my DVM nearby to check the resistance.
Computer codes as follows:
12 - Battery or computer recently disconnected
33 - Air conditioning clutch relay circuit open or shorted (may be in the wide-open-throttle cutoff circuit)
42 -
42 Automatic shutdown relay circuit open or shorted
42 Fuel pump relay control circuit
42 Fuel level unit - no change over miles
55 - End of codes
All the fuses are good and the relays seem to be working fine. When I bought the vehicle I vaguely remember a friend of mine fixed a part of the wiring harness under the under-hood fuse box. The connection was very corroded. I cut the tape off the harness but the wiring looks pretty good in there. Any particular wire (color?) I should look at, or am I chasing the wrong thing?
Old 08-07-2005, 11:56 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 91 Dakota no spark
that code 42 is your problem the ASD relay circuit normally caused by a tripped ASD relay. Try replacing that and seeing what goes.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 08-08-2005, 01:04 AM
Sar Sar is offline
I've already swapped the relay, no go.
