Go Back   Automotive Forums Car Chat > Opel/Vauxhall > Corsa/Barina
Old 08-07-2005, 11:12 AM
brightsparx1986 brightsparx1986 is offline
corsa 1999 help!!
how do you get the wheel arch surrounds off?? HELP!
Old 05-07-2006, 10:28 AM
corsab1999 corsab1999 is offline
Re: corsa 1999 help!!
[quote=brightsparx1986]how do you get the wheel arch surrounds off?? HELP![/quote
hey its quite simple . the rear suroundings are held on by 10mm bolts remove them . spray the nuts with wd40 . do it slowly as the plastic clips can break when removing the nuts.
the front is a bit more to it . u need 2 remove the actual plastic arch . theres a bolt its like a triangle remove it with a pair of pliers . then remove all the litle ruber washers with a flat hed screwdriver . prise them open . once u have done that its the same process as the rear . dont rush the job as i broke the clips on the front left . u need 2 take your weels of by the way . gud luck
ryan
