Go Back   Automotive Forums Car Chat > Oldsmobile > Achieva
Old 08-07-2005, 10:32 AM
TheDRS TheDRS is offline
96 Achieva strange electrical problem...
My girlfriends 96 achieva is draining the battery while the car is off. When you put the key in the ignition is makes a whining/buzzing sound from the steering column which stops if you click the turn signals on.
We just got a new battery for her 4 days ago and its drained.
I cant think of anything else to add, if anyone needs more info to possibly diagnose feel free to ask me. =)
Any help is appreciated.
Old 08-14-2005, 01:26 PM
anusemoon anusemoon is offline
Lightbulb
its called parasetic drain when you loose voltage overnight......
it could be a short in your multicontrole switch ( turn signal, light switch and cruise controle switch) which is sucking voltage and killing your battery..if you keep buying batterys it will happen over and over... i recomend to change the multicontrole switch( not a cheap fix)
Old 08-14-2005, 04:48 PM
Thumbs up
they have this multifunction switch on ebay......you have to do a lil research and find out if it will work on your car.....call a local dealer and ask for the part number...if it matches buy the one from ebay..... http://cgi.ebay.com/ebaymotors/NOS-9...93275080QQrdZ1
Old 08-15-2005, 03:14 PM
Thanks for the reply, much appreciated.
