Old 08-07-2005, 02:56 AM
jestersrain's Avatar
jestersrain jestersrain is offline
Send a message via AIM to jestersrain
ecu help
hey so the ecu on the si is throwing 3 slow blinks and 20 fast ones whats that mean its 2 different codes if so thanx for the hellp and next time ill try not to be so dumb
1991 HONDA CRX Si dead and gone you will be missed
Old 08-07-2005, 03:15 AM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
Code 3 or 5 Manifold absolute pressure
Code 20 (20 flashes) Electric Load
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 08-07-2005, 03:31 AM
Re: ecu help
ok so what could that be and would it stop the car from turning over cuz it just clicks when you turn the key
Old 08-08-2005, 02:32 AM
Re: Re: ecu help
First check for the 3 main things.
Spark
Fuel
Electricity
||JEFF| |
Old 08-08-2005, 03:52 AM
Re: ecu help
well see thats the thing it will run if we push start it but it wont turn it self over it will just click and when ever its running theres a ping'n sound like a chunk of metal is bouncing around in side the motor and the high the rev the more ping'n there is and its not steady which is y i said it sounds like is some thing boucing around
Old 08-08-2005, 05:41 PM
Re: Re: ecu help
Did you check the Starter ??
Maybe a piece of the gear broke off inside
||JEFF| |
