Go Back   Automotive Forums Car Chat > Chevrolet > Prism
Old 08-07-2005, 12:05 AM
prizmowner prizmowner is offline
1999 prizm LSI HVAC fan speed switch problem
Hi there,
I am having a problem with my 1999 PRIZM LSI HVAC fan speed switch. The switch operates only at the highest setting and not at the other settings. Just wanted to know if other PRIZM owners encountered this problem and if they would be kind enough to share the fix for this problem.
Thank you,
1999 Prizm owner
Old 08-09-2005, 12:23 PM
johnholl johnholl is offline
Sounds like a faulty [open] blower-speed resistor pack. Let me check the manual to gather how much of a pain accessing this component is.
If its an easy fix, I'd hit the junk yards for the part. GM and Toyota would probibly charge you an arm or leg
John
Old 08-10-2005, 11:29 AM
Re: 1999 prizm LSI fan speed switch problem
John
Hello John,
Thanks a lot for your help. Any further help in determining the blower resistor-pack location and replacement details would be appreciated.
Sharat
Old 08-15-2005, 01:44 AM
Kepha7 Kepha7 is offline
Resistor
The EXACT same thing just happened to my Prism. The resistor that was installed is a bad part. I went to the salvage yards and pulled several of them out and they were all burnt out also. The new (improved) part you need is only about $16 if you get it online. The part number is 89018516. Your resistor should be located under/behind the glove box on the passenger's side. You should see some wires going into a black connector with a grey latch. Pull on the latch and disconnect the wires. There are two screws holding the resistor in place...take those out. The resistor should just pull right out from there. When you put the new resistor back in, just make sure that the latch is facing the same way as before. Here's a pic http://files.automotiveforums.com/ga...?ppuser=366905
Old 10-21-2005, 12:43 PM
barfarf barfarf is offline
Send a message via AIM to barfarf
Re: Resistor
Kepha7 Where online did you order that blow resistor part? I looked online for a while and even used the part number you mentioned but i cant find it. PLease help.
thanks
ps. thanks for the pic it was a big help in finding it.
pps. I have a 1999 Chevrolet Prizm - 3 speed automatic transmission - 1.8L
Old 10-23-2005, 12:48 AM
I found the part online at http://www.gmpartsdirect.com Just type in the part number in the search window and it should pop up. I just realized that they add $10 for shipping, so it comes to about $25. I got my part from a Chevy dealer for $30. For the extra $5, I would probably just go and get the part from the dealer...just feels safer and its easier to return or exchange if it doesn't work or you get the wrong part somehow.
Todd
Old 10-25-2005, 11:44 AM
Wink Re: 1999 prizm LSI fan speed switch problem
Thats for the help kepla7. I pulled the burned out motor resistor from behind the glove box. It was easy, only two socket screws to remove. I did NOT even have to remove the glove box.
I have two pictures if anyone wants to look at how burned the thing was...its on my gallery.
http://files.automotiveforums.com/ga...?ppuser=393315
On the part i removed this is what it said.
P/N 52475256
REV. B
07-17-98
So for my 1999 3-speed automatic transmission Chevrolet Prism the part number was #52475256. Different for then what kepla7 mentioned ealier.
I ordered it for $31 here..
https://www.trademotion.com
I could have gotton it at my GM dealer for the same price but i would have to pick it up and i am lazy. This way it will be delivered to my house. I hope this helps someone.
Update-
Darn I just found the same part for $24 total here.
carparts.com
Old 11-26-2005, 12:09 AM
jrehm jrehm is offline
Ditto on the burnt resistor pack. Gotta replace one for the second time when I get around to it.
Old 06-05-2006, 04:45 PM
ELindy ELindy is offline
It sounds like this is a common problem with the Prizm. I got a new one at the Chevy dealer for $30. Autozone said they could order one for $16 if I came in and paid for it in advance. I'm not sure what you would get from Autozone as far as quality. The one I got from the Chevy dealer is branded ACDelco and it looks to be a lot better quality than the old burned up one. The old resistor is printed on circuit board like plastic and the new one is bonded to a metal plate, I assume for the heat sink properties.
Hopefully it is engineered better and will last.
Old 01-14-2007, 11:42 AM
n1ckml007 n1ckml007 is offline
My HVAC fan only now blows on the "high" setting. I have a 1999 Prizm with 101k miles on it.
I ordered ACDELCO Part # 158755 {replaces 52475256 #52475256} from http://www.rockauto.com
I will try to re-post when I swap the part in. $25.16 with shipping.
Old 01-19-2007, 05:00 PM
So fairly easy swap, upside down on passenger seat with a headlamp on and a 7/32 socket . The old resistor pack is burned to crap, the newer part looks like a much better part and now I have a variable fan again for $25!
Old 07-03-2009, 12:08 PM
prizm99guy prizm99guy is offline
Well I'm glad to have found this thread from a google search. The info was very helpful and I replaced the resistor without too much trouble. Thanks guys.
Old 12-01-2010, 09:48 PM
likemyprism likemyprism is offline
Thanks for the spot-on tip which saved me a trip to the garage. I ordered the part from www.rockauto.com and it's arriving in two days. I'm looking forward to using the variable speed fan in the cold weather.
BTW, I get 34 mpg on the highway and love the ride Too bad they discontinued this car.
Old 06-06-2014, 10:34 PM
Mithridates Mithridates is offline
Talking Re: 1999 prizm LSI fan speed switch problem
Just did this repair on my beater. Worked like a charm. Many thanks to the contributors on this thread.
