Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 08-06-2005, 08:55 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Hotshot Mod..... Part Deux...
Some of you may remember my Hotshot Mod from back in 2004.... http://www.s10forum.com/forum/showt...ht=hot+shot+mod
Essentially Hotshot is a freon replacement for r12, r134, and r504 freon that's compatible with all oils. The code for Hotshot is r414b.
Well I bring the subject up again because of recent issue (or ongoing depending on how you look at it).
I've not turned on the AC much this year because my compressor had a bad clutch bearing in it and it was really driving me nuts. Every time my wife would pull out of the driveway I could hear the compressor grind at idle (went away when you gave it gas).
Finally I got off my lazy butt and instead of changing just the bearing then gapping the clutch properly and all that happy crap, I simply just got a new compressor from Advance (128.00).
So I let all the old stuff out by removing the main lines to the compressor and wait until my headache from inhaling the stuff goes away. Takes about a 1/2 hour to load in the oil and throw the new compressor in and get everything back together at Grapplers.
So I go over to my clients house (he's an HVAC tech) and he whips out the r414b tank (AKA Hotshot). Vaccumes out both the high and low side (be surprised about the amount of pressure that builds with normal air in a ac system from engine heat). Loads up 1pound, 12 oz of hotshot (10% less than r134).
So he has me crank up the car, put the ac on MAX and the fan on high., Whips out his freon detector and starts checking for leaks...Found none at highest sensitivty.
So we give it a couple of more minutes and he pulls out both the laser thermometer and the wired one.
Right (glovebox) vent, 38 degrees, both center vents: 31.2 degrees final reading, driver's vent: 39 degrees final reading. Yes, eventually stuff freezes up, stops for a minute and comes back on, this is a normal cycle even with r134.
So all in all, I still can't reccomend this stuff enough!
Apparently in the industry it was originally said that r134 was going to be it for cars, fridges, freezers, et-al. Apparently this isn't the case. The industry is moving towards r414b and other similar freon formulas because of how crappy r134 tends to be overall.
So look for this stuff and similar replacements to r134 people. We'll all be much happier...(I'll be happiest if I could switch to some sort of peltier cooler...sigh)...
On your next recharge, find a local hvac person and ask for Hotshot, r414b refrigerant, shit can't be beat!!!
Old 08-06-2005, 10:23 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Hotshot Mod..... Part Deux...
You allowed refrigerant vent out into the atmosphere?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-06-2005, 10:27 PM
rlith's Avatar
Re: Re: Hotshot Mod..... Part Deux...
Well considering I don't have my own recovery tanks and tools, and the fact I doubt the ozone layer will be destroyed in my own lifetime, and the fact that a pound of r414 has less hydrocarbons than a styrofoam cup, I wasn't exactly worried about it.
Old 08-06-2005, 10:33 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: Hotshot Mod..... Part Deux...
Thread is closed until the administration allows this to be posted or not.
You are promoting an illegal and lazy activity by selfishly venting refrigerant into the environment.
We cannot condone illegal activities here and for anyone thinking this is ok or legit, if your neighbour calls the authorities on you, you will be charged and fined over $2000-$5000 for your stupidity. This has been done lately.
So Rlith, how about practising methods that help the environment, not hurt it.
If everyone thought their "little bit" didn't hurt we would all be living in a toxic mess now.
Closed Thread
